Posted: Saturday May 5th, 2007 04:11 am |
The new Beta version 2.1.4 of Comfigurator is available for download from http://www.cytech.biz/software/html
There are bug fixes from the previous 2.1.2 version and also new features
The licence checking has been removed so Comfigurator can be used with any UCM with a Rs232 or Ethernet interface
The interface for Zones, Zone Types and Alarm Types has been improved so that it opens a pop up window to allow easier editing of all fields
Download will now require Engineer Code sign in. This prevents unauthorised user access. However F0 MUST be pressed on the keypad to allow Engineer Code to sign in. Note that it will not be possible to download when the Engineer code is not known
The new version supports Sunrise/Sunset times but this is not available in Firmware yet. It is for testing purposes.
There is also a new Firmware download feature which is also not supported in the product yet. This is for testing purposes
V 2.1.4 - 30 April 2007
Beta version of Comfigurator
Bug fixes - Fix problem with response compilation if response number = 255
- Fix problem with erroneous values in event log listing
- Save CCL values using English locale to avoid problem with comma as decimal point in Siren duration
- Limit counter value in IF statement to 254 to avoid erroneous end of response detection
- Fix incorrect values set for reminder message destinations
New features - Hide ringer details for Comfort II
- Remove licensing checks
- Remove alpha pager
- Require engineer code for up/download
- Disable UCM concatenate if not CBUS
- Launch WizComfort
- Edit zones, zone types and alarm types using popup dialogs
- Right-click on zone type in zone popup to display/edit zone type
- Add descriptions and enable editing of tuning parameters for Comfort II
- Associate names with X10 transmitted codes (referenced within responses)
- Support UCM type Rako
- Support UCM type Lutron
- Support UCM as target for reminder messages
- Display some actions in more than one category in Response Wizard
- Support Sunrise/Sunset times (NOT IMPLEMENTED in FIRMWARE)
- Support firmware download (NOT IMPLEMENTED in FIRMWARE)
We have listed known bugs in Version 2.1.2 namely
Known Bugs - Incorrect Locations for Access User Responses (For Fingerprint reader)
- Entering Incorrect Action Codes can cause Comfigurator to crash (eg 89, 69, 128, 255 )
- Branch action codes entered manually are not coded by Comfigurator eg: 113,3,128,1,1,128,2,1,255.
- Voice download sometimes has an error causing no voice on system. Need to resend last line eg v!05FF1A010103, after the reset.
- Reminder Message has incorrect values for All Keypads/doorstations
Posted: Saturday May 5th, 2007 12:38 pm |
Posts: | 788 |
I have just named X10 A1 as "houselight"
Created a response and used "houselight" - it came up with invalid X10 code!
Attachment: X10 invalid.ccl (Downloaded 6 times)
Posted: Saturday May 5th, 2007 12:40 pm |
Posts: | 788 |
So where do you use a sensor response how is it defined - Help gives nothing away!
Posted: Saturday May 5th, 2007 02:03 pm |
adlim
Posts: | 210 |
Its meant for the SCS for temperature sensing. The SCS manual will provide more details. Cheers
Posted: Saturday May 5th, 2007 03:16 pm |
lms
There appears to be a problem with the X10 Recieve Codes.
Load ccl in Comfigurator 2.1.4beta - no X10 receive code responses are shown but they're in the CCL. Save the file from Comfigurator and you lose them!
Tried adding a few and saved the file. They get saved in the CCL but when you re-open Comfigurator they don't show up again and disappear from the CCL when you save the file!
Posted: Sunday May 6th, 2007 01:53 am |
Thanks. This will be fixed in the next release
Posted: Sunday May 6th, 2007 02:10 am |
That does seem to be a problem that should be fixed soon
Posted: Friday May 11th, 2007 03:13 pm |
Posts: | 5845 |
A known bug with 2.1.4 beta is when a file has been saved, it corrrupts the Siren Types. This results in strange sounds from the keypad when beeps or other sounds are supposed to be heard. We have removed the file for the time being
Please use 2.1.2 which is an interim release see the list of known bugs in the topic http://www.comfortforums.com/forum20/369.html
Posted: Friday Jul 6th, 2007 06:16 am |
