Posted: Tuesday Nov 14th, 2006 07:15 pm |
GushK
Posts: | 4 |
I'm having trouble running Comfigurator on Windos Server 2003.
I've never been able to run it, since my first download of v1.6
I've tried v1.6, 2.0 and 2.1, complete remove/reinstalls
also followed
http://finance.groups.yahoo.com/group/comfort-technical/message/3492
to remove any registry keys
Installation completes ok but trying to run it always comes up with the message
"Installation corrupted- please reinstall"
Any ideas?
G S Kainth
Posted: Wednesday Nov 15th, 2006 01:47 am |
Have you tried this on another machine with the same OS?
Posted: Wednesday Nov 15th, 2006 08:27 am |
GushK
Posts: | 4 |
Unfortunatly I don't have another Server 2003 machine to test on but it's interesting to note that WizComfort works perfectly fine on this machine when pointed at the Comfigurator installation
Posted: Monday Nov 20th, 2006 07:51 pm |
GushK
Posts: | 4 |
Right, installed comfigurator on another machine, freshly installed with server 2003 and.... it works.
Now i'm stumped. I can't reinstall the main machine, because it's running so much stuff.
What options does that leave?
is there a debug mode for comfigurator I can use and email u the log output?
G S Kainth
Posted: Sunday Apr 15th, 2007 02:44 am |
This applies to Comfigurator 2.1.x being installed on Windows Server 2003 R2
If you get the Error message “installation corrupted – please reinstallâ€. when you try to launch the application aftre installation, try these steps:
- Go to My Computer, right click on it, and go to Properties …
- Go To Advanced tab and click on the settings button of Performance
- Then go to the third tab ‘Data Execution Prevention’
- Change setting to the following ‘Turn on DEP for essential Windows programs and services only’
Many thanks to Paul Gordon (UK) for brining up the problem and Bart De Pooter (Belgium) for the solution
Posted: Thursday Jul 5th, 2007 07:01 pm |
nicr
Posts: | 2 |
Has anyone managed to solve this problem. It seems that there are 2 other similar issues that have been posted on the forums. None of them have a response.
I have just installed tried to install comfigurator on a brand new vista machine (all service packs and patches applied) and have the same problem. I have also tried various versions of the software, but the all have the same problem.
I have tried running the app as administrator, set Windows 2000 compatibility mode. Nothing.
If no one has been able to solve the problem, could one of the Cytech folks comment under which circumstances the message is displayed. Maybe that can help us try to solve the problem.
Unlike the other postings, I can't put the software on a new machine, so I'm stuck.
Please help.
Nic
Posted: Thursday Jul 5th, 2007 11:47 pm |
Ian Clarke
Hi Nic,
I cannot offer much help, but to say that it works fine on my Vista Basic acer laptop.
All versions including the new 2.2.0.
Sounds like you have some local curruption on your machine.
Regards Ian
Posted: Friday Jul 6th, 2007 01:07 am |
Posts: | 5845 |
The problems posted regarding installation of Comfigurator on Windows Server 2000 was already replied and addressed in the post which has now been merged with this topic, see above dated April 19 2007
There are no issues in which there are no responses
In your case, can you be more specific as to what error messages you received when you tried to install the software in Vista. There have been several customers on Vista already who have no problem installing and running Comfigurator
regards
Posted: Friday Jul 6th, 2007 07:04 am |
malgre
Posts: | 8 |
Which version of Comfigurator are you attempting to run? The error you report suggests a problem with the licensing checking, but this has been removed in the latest version. If you're not using 2.2.0 then please do so. If the problem persists, please provide details of which version of Vista you're using - it runs with no problem here on Vista Ultimate.
Malcolm Green
Posted: Friday Jul 6th, 2007 08:14 am |
Just to add my note, I had no problem getting 2.2.0 or the previous 2.1.2 interim version of Comfigurator running on Vista Ultimate either. I am connecting via UCM/Ethernet so if there was an issue with licencing checks before 2.2.0 then I presumably didn't see it as the UCM/Ethernet licencing I understand circumvents this?
Posted: Friday Jul 6th, 2007 08:10 pm |
nicr
Posts: | 2 |
Hi, thanks for all the responses.
Here's the weird thing - after reading all of the responses, I decided to write down step-for-step what was happening. Lo and behold, it now works. I cannot explain it, but it must have something to do with shutting down the machine and then restarting it again now.
To anybody else having this problem, I suggest the following. Uninstall. Shutdown. Restart and hope for the best. That is pretty much the sequence in which I did things.
Once again, thank you everyone for the prompt response.
Nic
PS: For those who wanted the extra information, here it is for reference.
1. I am running Windows Vista Business
2. I've installed the latest 2.2.0 from the website (Comfigurator2.2.0_Single.zip).
Posted: Saturday Jul 7th, 2007 06:49 am |
Ian Clarke
Hi Nic,
the number 1 rule for any Windows problem, is to reboot. If that does not work re-apply rule number 1.
Regards Ian
