Comfort to Dynalite
 Posted: Monday Aug 7th, 2006 01:50 pm
Comfort can be interfaced to the Dynalite lighting system (http://www.dynalite.com.au) using a UCM05 and DNG232 from Dynalite. This allows Comfort to control Logical Addresses on the DyNet. Comfort acts as a controller for the Dynalite system, providing for the following benefits:
  • telecontrol through any telephone inside or outside the premises to control devices on Dynalite’s DyNet
  • allows control from Comfort’s keypads
  • allows control by Comfort’s Time Programs
  • allows Comfort’s Webserver Module (CWM) to provide Internet access to control Dynalite devices
  • allows alarm inputs and alarm conditions to be linked to Dynalite for true integration of alarm and lighting
  • functions as a central controller for Dynalite DyNet network. Dynalite is a distributed control system with each device having its own intelligence and able to responds according to its own device type and the way it is programmed. In an intelligent home or office environment, it may be desirable to have a controller that coordinates the functions of the various subsystems including security, lighting, HVAC, and others. Comfort is able to take conditional logic; for example, when the time is between 7pm and 7am, and the security system is armed, when the front door is opened, the hall lights may be switched on for a period of 3 minutes. This would not be possible purely from a Dynalite system alone.
The UCM05 connects Comfort to Dynalite's DNG232. The commands to set scenes in Dynalite can be configured using Comfigurator when one of the UCMs is selected as a Dynalite UCM (in Names > UCMs)
The UCM/Dynalite  Application note  can be downloaded from here
 Posted: Thursday Feb 26th, 2009 01:38 am
See the case study at http://www.comfortforums.com/forum54/1319.html called "Cheshire Smart Home"
showing integration of Comfort with Dynalite (using DNG232)
 Current time is 10:40 am
