Companion/SideKick to Comfort
 Moderated by: ndh
 Posted: Sunday May 6th, 2007 01:43 am
mgfair
Can SideKick be connected to Comfort through the RS232 serial interface of CWM?
Alternatively,if the UCM/Ethernet board is used to connect rather than the CWM, I assume that there is no serial connection between Comfort and SideKick, if what are there any issues with this?
 Posted: Sunday May 6th, 2007 02:03 am
adlim
That port for the CWM is meant for a dialup modem connection.
The UCM/Ethernet is used similar to a serial UCM. What issues do you refer to? I do not see any issues with this so far.
 Posted: Sunday May 6th, 2007 03:50 am
mgfair
Thanks for the reply.  I do not know if there are any issues (eg reliability, flexibility, functionality) - hence - the question.
Baiscally, I am trying to determine which UCM(S)/modules I need to connect Comfort to:
1. SideKick;
2. The Gigabit network around my home; and
3. The internet.
Mark
 Posted: Sunday May 6th, 2007 06:54 am
If you can get the UCM05 serial interface near the Sidekick, then that would be a cheaper option than the UCM/Ethernet, as Rs232 can only go about 10 meters
To connect to the Ethernet/Internet you need the UCM/Ethernet
 Posted: Sunday May 6th, 2007 08:55 am
mgfair
Thanks but your reply does not really answer my questions, see above.  I asked about reliability, functionality etc.  Let me ask another way, is a short run RS232 serial connection a more stable solution than ethernet? (note SideKick only has 1 network port).
Anyway - I suppose it is possible to have the UCM/Audio and either the UCM/Ethernet or CWM installed into Comfort?  The RS232 on the UCM/Audio can be used to connected to SideKick (with audio) leaving SideKick's only network adapter to connect to my ethernet switch.
M
 Posted: Monday May 7th, 2007 01:14 am
adlim
Both should work as well.
Yes, you can have the configuration as you stated. Comfort allows the combination of up to 8 UCMs (of any type) in its system.
 Current time is 05:51 pm
