What to use to replace X10
 Moderated by: adlim
 Rating:  Rating
 Posted: Wednesday Nov 27th, 2013 07:14 pm
mccltd
I'm upgrading my comfort 1 to a 2 shortly and at the same time think it maybe time to replace my 10 year old X10 modules.
I currently use soft touch X10 light switches and appliance modules around the house.
What is now the most cost effective route to go that the comfort ii will control please?
regards
Dave.
 Posted: Wednesday Nov 27th, 2013 10:38 pm
mikegriff
As dimming is a problem now with LED.
I would suggest relays with Comfort
plus contactors where heavy current is needed.
Mike
 Posted: Thursday Nov 28th, 2013 12:57 am
The closest  replacement for X10 may be Zwave but more complicated to setup and may have problems with certain manufacturers, see the Zwave forum
Other alternatives are Velbus, Cbus, KNX
 Posted: Thursday Nov 28th, 2013 05:51 am
Please expand as im using dimmable LED with zwave.
juwi
 Posted: Thursday Nov 28th, 2013 06:13 am
mccltd
Thanks for the advise. Looks like i will give zwave a go.
Can I use this on my comfort 1 till I install my upgrade?
Is there a simple guide to programming Zwave that you can recommend?
Also Juwi_uk what wave device do you use with Led as I have quite a few LED Gu10's in my house that I can't currently control with an X10 light switch.
Many thanks
Dave
 Posted: Thursday Nov 28th, 2013 06:49 am
I am using Fibraro dimmers with bypass module (needed for LEDs if load <25w) fitted. My LEDs are various, some dim some dont. My dimming ones are Philips LedSpot mv gu10 in a couple of variations; some ie kitchen are recessed and others retrofit to existing ceiling fittings.
 Posted: Thursday Nov 28th, 2013 06:57 am
wexfordman
Hi Mcc,
I did same recently (about two years ago) and I went the velbus route and haven't regretted it.
Did an overview on it which you can find here if you are interested https://docs.google.com/a/glenegare.com/file/d/0B1zlDoqP2HdxNWd0LXdhWGRIVW8/edit?usp=docslist_api
 Posted: Thursday Nov 28th, 2013 07:19 am
Yes, velbus is an excellent solution if you dont need wireless, very stable and easy to configure
 Current time is 06:11 am
