Compatibility with CM11 PC interface
 Moderated by: adlim
 Posted: Tuesday Jun 29th, 2010 04:07 pm
ekarak
Can I connect Comfort to a legacy CM11 (Eurolpug) adapter? it uses the same 4-pin RJ11 to serial (RS232) cable as the TW523. thanks
 Posted: Wednesday Jun 30th, 2010 12:55 am
If I am not mistaken CM11 is a Rs232 interface for connection to a PC, not with a RJ11 jack, so that could not be connected to Comfort
 Posted: Wednesday Jun 30th, 2010 07:50 am
ekarak
yes, CM11 it is a RS232 adapter for PC but it has a RJ11 plug and a special cable with a male RS-232 adapter on the other end.
http://www.reallycleverhomes.co.uk/acatalog/Marmitek_CM11_USB_X10_PC_interface.html
 Posted: Wednesday Jun 30th, 2010 08:40 am
We dont know if that RJ11 is the same port compatible with the one on the TW523 or XM10E, but I doubt it  if the other end of the cable is a RS232 or USB connector. The cable seems to be just a converter for the different connectors. I suggest you get a XM10E from Laser or other X10 suppliers to be sure of getting it to work
 Current time is 07:59 am
