Comfigurator 3.14.X
 Posted: Sunday Oct 22nd, 2023 05:19 am
Comfigurator 3.14.1 Changes from 3.13.9
Known Bugs
  1. Upgrade firmware for Controller shows "Cannot Obtain Firmware Information". Workaround -  Please download firmware directly from http://www.cytech.biz/firmware.html Or downgrade to 3.13.9 at http://www.cytech.biz/download_files.php?item_id=1301
  2. Upgrading KP04, KP06, IRIO, MSM, TSM by Coimfigurator will case an error "Incompatible File System" to be displayed. Revert to 3.13.9 as workaround
  3. The number of IRIO Modules are not correctly detected after scan for modules for CM9001-EMS and CM9001-EMS2
  4. For UCM/KNX and KNX/Logic in KNX Monitor Mode, when logged in by eth03 in CM9001  telegrams do not appear in KNX Monitor or Learn Mode
Bugs Fixed
  1. For CM9001-EMS, No of slaves was limited to 3, now it can be increased to 5
  2. For CM9001-EX, No of slaves was limited to 3. Now it can be increased to 5
  3. The action Set Virtual Input On/Off could not select Virtual Inputs correctly
  4. When UCM ID1 is not connected, and Comfigurator is connected to UCM > ID2,  Scan for Modules may show an extra UCM ID1 with firmware version 255.255
New Features and Improvements
  1. For the Register Monitor in Comfort Register, the right Pane Set Value box does not show the value of the register, so that if the value is constantly being updated, entering a new value will not be affected by the read values. The centre pane will show the register values that are updated constantly
  2. Supports Future UCM ARM processor models
 Posted: Thursday Nov 2nd, 2023 06:01 am
Comfigurator 3.14.4
  1. Fixed bug from 3.14.3-  Upgrade firmware for Controller shows "Cannot Obtain Firmware Information"
  2. For UCM/KNX and KNX/Logic in KNX Monitor Mode, when logged in by eth03 in CM9001  telegrams do not appear in KNX Monitor or Learn Mode
Known Bugs
  1. If a new Comfigurator file (template)  is started with a Comfort with IRIO, logging in will produce an exception. If a saved  file with IRIO already present, this will not happen. As a workaround, add the IRIO manually and do a module  scan again
  3. IRIO Properties for ISM01 Temperature sensor > Calibration offset - value -1 is always written - This is an old bug
  4. The number of IRIO Modules are not correctly detected after scan for modules for CM9001-EMS and CM9001-EMS2
 Posted: Friday Nov 24th, 2023 04:30 am
Comfigurator 3.14.6
Known Bugs
  1. The number of IRIO Modules are not correctly detected after scan for modules for CM9001-EMS and CM9001-EMS2
Bugs Fixed
  2. Fixed Bug Upgrade PIC based products shows "Invalid File format"
  3. Fixed Bug IRIO > ISM Submodule > Temp sensor> Calibartion offset always writes FF
 Posted: Friday Jan 12th, 2024 01:57 am
Comfigurator 3.14.8
Bugs Fixed
  1. The number of IRIO Modules were not correctly detected after scan for modules for CM9001-EMS and CM9001-EMS
  2. For UCM/KNX and KNX/Logic in KNX Monitor Mode, when logged in by eth03 in CM9001  telegrams do not appear in KNX Monitor or Learn Mode2
  1. Sensors mapped to external modules are now unique ie you cannot map the same Comfort sensor register to different modules eg KNX, Modbus, IRIO. This is because Sensors represent temperature, humidity and other sensor values obtained from external sources. Allowing different modules to map to th same sensor would cause incorrecvt values to be assigned to the sensor. This feature ensures that different sensors must be assigned
Note - after upgrading the software, it is best to do File > Update Defaults to update the default files form thee server. After that restart Comfigurator
 Posted: Friday Aug 2nd, 2024 02:39 am
Comfigurator 3.14.10
Bugs
  1. For UCM/KNX and KNX/Logic in KNX Monitor Mode, when logged in by eth03 in CM9001  telegrams do not appear in KNX Monitor or Learn Mode
  2.  When File system in converted to another, sunset responses always writes 0000
New Features
  1. Improved detection of Comfort Modules including ARM-based products
  2. Important - Please do File > Update Defaults to update the default configuration files so RIO Modules outputs can be handled correctly  in responses. This fixes the problem in Comfigurator that RIO responses give errors in red
  3. Misc Events > Sunset Responses - This parameter is not written to Comfort (written as Response 0)
 Posted: Wednesday Jan 29th, 2025 12:14 am
Comfigurator 3.14.12
Bugs
  1. The calculation of DC Voltage is wrong
  2. some newly created cclx files may cause exception when  opened
Bugs Fixed
  1. For UCM/KNX and KNX/Logic in KNX Monitor Mode, when logged in by eth03 in CM9001  telegrams do not appear in KNX Monitor or Learn Mode.
  3. Defaults for Number of IRIOs have been updated
  4. One cclx file Flag 1 Graph References caused Exception
  1. Controller Properties will display Battery Voltage and DC Voltage Value for Arm Processor only (using the D? query). NOTE! there is a mistake  in the calculation of DC Voltage
  2. IRIO Sensors - added parameter for interval between Updates to avoid flooding the RS485 Bus - which caused Comfort Register  Monitor to not update correctly
  3. Supports new KNXA/Logic for Arm
  4. UCM/GSMA7608 Type is shown as A7608 instead of "4" in GSM Properties
  5. Scan for modules will return with Battery Voltage and DC Voltage values in Controller Properties
 Posted: Friday Feb 14th, 2025 01:39 am
Comfigurator 3.14.14
    • fixed bugs some cclx files when opened have exception
    • improved D? analog values for DC not correct
 Current time is 11:51 pm
