Posted: Saturday Mar 28th, 2020 03:00 am |
Posts: | 5841 |
Known Bugs (Remaining)
- Responses with AND and OR Conditions after Read from Comfort are decoded incorrectly. If you have such conditional actions in any Response, do not Read from Comfort except for checking only. This bug is from long ago
- Action Set Virtual Input does not select Virtual Input, selects physical input instead
- UCM/Cus2 Cbus to Comfort Output status is wrong when map to lighting group address. Output -1 status is shown instead of output number status
- Set login partition action has error
- Security Node Responses and siren outputs programmed in old cclx files are not in Partition events when opened in 3.13.5
Bugs Fixed- Fixed Bug IRIO analog output registers not shown as referenced
- Fixed Bug IRIO with modules. eg ISM01. Open new file and scan for modules. IRIO is detected, click on IRIO, ISM01 is seen but we cannot see any IO under ISM01. We must select None or other submodules then select ISM01 then the I/Os under ISM01 can be seen
- Fixed Bug "Subtract sensor from last action" was wrong
Changes- Added Occupancy status on the status bar, to show if the premises is occupied. See http://www.comfortforums.com/forum20/5158.html
- Occupancy commands dR or d? Occupancy Active/Inactive
- Action 73, 32 Get Occupancy Status (73,32)
- added Support for Wifi submodule (coming)
- Added Timers status to register monitor.sort by name and number. However the register values canbot be changed. See http://www.comfortforums.com/forum20/5149.html
- IRIO modules if IRIO was present but now is not found, dont give error messagfe to avoid several error messages due to Submodule not correct
Posted: Saturday May 23rd, 2020 08:01 am |
Posts: | 5841 |
Comfigurator 3.13.2 (Beta)
New Features and Improvements- Register Monitor allows change of register values
- Register Monitor includes Timer values
- In Responses, when any Comfort Register is used, the Register number is appended, eg Get Counter Dim (7) The counter named Dim shows the Counter number (7)
- Events > Partition Events now has Security Off Response, Away Mode Response, Night Mode Response, Day Mode Response, Siren Outputs. These have been moved from the Misc Events Screen for better organisation, and allows more partitions to be added later
- New UCM/wifi module support has been added.
- UCM/Modbus will allow wifi interface and Virtual Input mapping for modbus not connected. This requires a new UCM/Modbus firmware yet to be released
Posted: Wednesday Jun 17th, 2020 06:44 am |
Posts: | 5841 |
Comfigurator 3.13.3
myma.cfg was missing from the installation. Starting a default template will have an exception.If you have download Comfigurator 3.13.3 on or before 18 June 2020 and have this problem, please download Comfigurator 3.13.3 again and reinstall
Known Bugs
- Sunset Response does not work even though the Night Flag is turned on at sunset
- Occupancy Timer in minutes is not written to Comfort
Bugs Fixed from 3.13.2- Initialise Counter - Counter value is always = counter number eg Counter 7 =7
- Ucm/LOGIC add UCM gets exception from 22/3/2019
- FS35 read user codes gets exception
- FS35 Partition events not correct -
- users engineer code is repeated, engineer code should not have authorisation
- In Existing cclx file created before 3.13.2, if UCM/ modbus is selected, an exception appears, but create new file and add modbus is OK
Changes and New Features- Partition Events have been moved to Security Category
- UCM/Modbus allow map virtual Input to modbus not responding. This requires a new UCM/Modbus firmware to be released
Posted: Wednesday Jul 15th, 2020 01:51 am |
Posts: | 5841 |
Bug in 3.13.3
This will be fixed in the next version
Posted: Thursday Jul 16th, 2020 12:08 pm |
Posts: | 5841 |
Comfigurator 3.13.4
Fixed Bug - Sunset Responses does not work
Known Bugs - Alarms > Partition Events> Responses (ie Security Off, Away, Night, Day, Siren Output )which have been programmed here become blank after saving the file. Wen the file is opened again, the Partition Responses are blank.
Please download from http://www.cytech.biz/product_details.php?item_id=206
Posted: Wednesday Aug 5th, 2020 08:51 am |
Posts: | 5841 |
Bug found in 3.13.4
Plrease do NOT upgrade from 3.13.1 if you have bot done so
If you have upgraded to 3.13.3 or 3.13.4, downgrading will cause errors in the responses due to the Register Numbers which have been added to the names after 3.13.1
Posted: Wednesday Aug 5th, 2020 11:50 am |
Posts: | 5841 |
To work around this problem when you have upgraded to 3.13.3 or 3.13.4;
If you have already done a fulll write to Comfort after upgrading to 3.13.2 or higher, The Away, Night Day, Security Off responses may ot be empty in Comfort.
Assign the Responses again for the partition mode responses, and write seletive or Full to Comfort.
Once you save the file, these Partition Events will be lost.
If you have to make changes anywhere in the configuration and need to write to Comfort again, do a Selectve Write and Exclude the Partition Events, so you do not write blank partitions events to Coomfort
Posted: Thursday Aug 6th, 2020 04:30 am |
Swiss-Toni
If you have down graded to 3.12 after finding issues using the latest version and still have problems, what would be the advice to take then as I guess that you are saying a down grade will still have the latent problems in partitionioned Zones?
As this is what I had done and have problems in the partioned zone (my workaround was to alter the zones that were used to speare zones and re-create.
Posted: Thursday Aug 6th, 2020 11:33 am |
Posts: | 5841 |
3.13.2 and 3.13.4 has the same problem as 3.13.4 ie Partition events are ostso you might as well upgrade to 3.13.4 and use the workaround that I mentioned in my last post
Posted: Thursday Aug 13th, 2020 10:47 am |
Posts: | 788 |
This is turning into a bit of a nightmare !
It now been MONTHS since this bug was reported and I'm getting complaints from customers that we have been to provide service etc that now have problems that they DID NOT HAVE BEFORE WE VISITED !
WHEN IS THE FIX AVAILABLE
WHEN CAN WE SENSIBLY DOWN LOAD 3.13.5 and KNOW THAT IS RELIABLE !
Not so worried about the partitions BUT things like the daylight are crucial !
Please advise soonest
Posted: Thursday Aug 13th, 2020 12:14 pm |
Posts: | 5841 |
I think you are slightly confused.
The bug in Sunset/ Sunrise Responses appeared in 3.13.3 on June 15, it was reported on July 15, and 3.13.4 was released in July 16 which fixed that problem - Hardly Months since t was reported.
Comfigurator 3.13.4
Posted: Thursday Aug 13th, 2020 12:29 pm |
Posts: | 5841 |
Comfigurator 3.13.5 Fixes the following Bugs from 3.13.4 - Alarms > Partition Events> Responses (ie Security Off, Away, Night, Day, Siren Output )which have been programmed here become blank after saving the file. Wen the file is opened again, the Partition Responses are blank.
Known Bugs
Also please note that the Partition Events bug that is fixed in this version 3.13.5 does not just affect Partitions.
Partition Events includes the Security Off, Away, Night, and Day Mode Responses which was in Miscelaneous Events. It has been moved to Partition events because each partition has a set of Security Off, Away, Night, and Day Mode Response. With versions 3.13.1 to 3.13.4, even if you haveno partitions your Security Off, Away, Night, and Day Mode Responses would not work
Posted: Monday Aug 24th, 2020 03:39 am |
Posts: | 5841 |
Comfigurator 3.13.5 has been released. Please upgrade.
Posted: Friday Oct 2nd, 2020 01:44 am |
Posts: | 5841 |
Please note that in 3.13.5, the Security Mode Responses (Away, Night, Day, Security Off) have been moved from Miscellaneous Events to Partition Events, so that they are groups with other events pertaining to Partitions, eg Siren Output.
see details in http://www.comfortforums.com/forum20/5216.html
Posted: Tuesday Oct 6th, 2020 05:29 pm |
garym999
Long time since I've been around! Hope you are well given the current situation?
Anyway's I have just had to visit/and charge a resonably compedent client that got burnt by the update nag screen, the sunrise/sunset issue and then the relocation of the Partition Events.
Reading this thread has been quite an unexpected eye opener given the issues listed and release dates.
Roll backs & testing has revealed that even this latest version does not correctly read previous config files and populate Partition 0 fields setting them all to Null Response.
So some thoughts...
Probably missed the reasoning, but why have an Events Tree that trys to contain all the responses and then relocate some of them? Partitions, Users etc. Probably just my old time familarality with Comfiguirator.
If the splash screen shows, indicating an update (Did I miss the option to turn this off BTW), it should also show the release notes or provide a link to them so one can better judge the impact of upgrading.
Gary
Posted: Wednesday Oct 7th, 2020 03:52 am |
Posts: | 5841 |
Yes there was a problem with versions 3.13.1 to 3.13.4, apologies for that3.13.5 fixes the known problems
The changes to move security off, away , night day, and siren output to Alarms >Partitions is so as to allow this to work when more partitions are added in future
You can see the old grouping
security off response partition 0,
Away mode response Partition 0night mode Partition 0
security off response partition 1,
Away mode response Partition 1
night mode Partition 1
security off response partition 2,
Away mode response Partition 2
night mode Partition 2..
was rather clumsy and diffucult to expand
Posted: Thursday Oct 8th, 2020 07:03 am |
17th Post |
garym999
Thanks for the update but what I'm pointing out is that if you take an older config file and load it in the latest Comfigurator the assigned responses for the responses are lost! And have to be put back into the config file. Meaning it is all to easy to upload an effectivley courrupted config. Added to which the only way to get back to the file and see what the settings should be is to roll back comfigurator.
Posted: Wednesday Oct 21st, 2020 07:52 am |
18th Post |
caravanboy
Posts: | 165 |
Wow, I'm glad I saw this thread. I've been on 3.13.3 since early July 2020 (looking at my folder dates). Fortunately I keep backups of every config change I ever make since they are only every couple of months or so and I just did a diff on the XML in a config from mid 2019 to the latest one yesterday.
You're definitely correct, garym999. At some point my old AwayModeResponse and NightModeResponse have been lost!! The new similar versions of those settings in the partition section are all null. I guess I haven't noticed it as their effects are very subtle in my config.
I'm now going to paranoidly look at all the other diffs to ensure no similar losses.
Posted: Thursday Oct 22nd, 2020 02:19 am |
19th Post |
Posts: | 5841 |
You can load an old cclx file by going to File > Restore from Backup. You will be shown a list of old backups that were automatically saved
Posted: Thursday Oct 22nd, 2020 06:23 pm |
20th Post |
garym999
That's not the issue.
The issue is loading a known good file that worked with previous configurators the Partition Responses do not carry over to thier new location in the latest configurator. Then you write the file out and the Security Off/Away Mode responses etc. do not get assigned.
And now you have no way of telling what responses were assigned previously. I removed Configurator, rolled back to an older version and installed, ignored the upgrade nag screen and then manually noted the response names. Then I could upgrade to the latest configurator and reasign the responses.
Fine if you are only working with one system but I have loads.
Current time is 11:01 pm | Page: 1 2 3 |
