Comfort Register Monitor
 Posted: Thursday Feb 20th, 2020 08:20 am
Register Monitor
The new Register Monitor feature is very useful when you want to monitor a range of Comfort registers; Zones/Inputs, Outputs, Counters, Flags, and Sensors. Before this, you had to go to Zones to monitor zones, Outputs to monitor outputs, Counters to monitor counters, etc. This new feature allows all required registers to be monitored in a single window.
Go to Comfort Registers > Register Window.
The Login window appears. Enter a valid  user code.
A new window appears "Add Register to Monitor"
Select Counter, Flag, Output, Sensor or ZoneThen select the register number according to the register type selected
Continue adding registers to the monitor window.
The real time status of the Registers are shown.
You can change the value of the register by cliicking on Status.
 Posted: Monday Apr 13th, 2020 08:37 am
Register Monitor includes Timer Status
In Comfigurator 3.13.1, you can add Timers Status to the Register Monitor as belowThis requires a new Comfort Firmware 7.174 (Not released yet)
Tis is extremely useful if you are using Timers as it lets you know what the timer status is for checking and troubleshooting Timer Responses
 Current time is 04:36 am
