Comfort Home Automation/ Security System Forums > Support > FAQs - Technical > Adding key switch to original Comfort panel
 Posted: Saturday Jun 20th, 2020 01:10 pm
mccltd
I have a comofort panel which must be about 18 years old now and still going strong. I presume its a comfort 1, not sure.
Any how's I wish to add a remote to arm / disarm the unit and if I recall correctly when I installed it there was an option to add a key switch arm/disarm.
I'm presuming I could link it this but is there any info anywhere about adding the key switch and do I need to go into the programming of he unit?
Thanks for your help
 Posted: Sunday Jun 21st, 2020 02:18 am
Connect the key switch to any zone and program it as Switch Nornally Open Zone Type
Assign one of the default responses
Momentary switch Keyarm/Disarm to Away mode
If SecurityMode = SecurityOff Then
    If AlarmState < Alert Then
        KeyswitchArm NightMode
    End If
Else
    KeyswitchArm SecurityOff
End If
If SecurityMode = SecurityOff And AlarmState < Alert Then
    KeyswitchArm AwayMode
Else
End If
 Posted: Sunday Jun 21st, 2020 01:22 pm
mccltd
Thats great, thank you.
I thought it could be done but couldn't remember how.
 Posted: Saturday Jun 27th, 2020 03:50 pm
mccltd
Hi SlyChiu,
I have just programmed the comfort with this and when I try shorting the zone 11 and common I get the Please exit and countdown but if I don't exit it goes back into security off.
How could I have it so that when using the keypad I need to exit but if using the key switch I don't need to exit and it still arms?
Dave
 Posted: Sunday Jun 28th, 2020 01:30 am
See the different ways of arming to Away Mode here http://www.comfortforums.com/forum125/2367.html
If you want to arm to away mode without having to exit, use the action "Auto arm Away" instead of "Key switch arm away mode"
 Current time is 07:00 am
