Posted: Tuesday Dec 12th, 2023 12:25 pm |
Sota
Posts: | 86 |
I have a UCM/Pi that failed a couple of years ago. I think it happend when uploading a firmware upgrade to it, either the file was corrupt or I used the wrong file.
At the time, I tried using the firmware programming cable without success so I just ordered a replacement.
I would like to recover it if possible, to use for testing and as a spare as I have a CM4 and a CM3 to CM4 adaptor. The PWR, RDY & ACT LEDs are green and I do see a flash from the Pi boot on the screen when I power it up, but then it goes blank.
Any thoughts on if it's possible to recover it?
Thanks!
Posted: Wednesday Dec 13th, 2023 02:12 am |
Posts: | 5758 |
I think it may be the UCM/PI baseboard that was corrupted by the attempted firmware upgrade.
I suggest to try the upgrade again with the firmware upgrade cable. do not connect any other cable to the ucm/pi except the firmware upgrade cable
Posted: Saturday Mar 9th, 2024 11:08 am |
Sota
Posts: | 86 |
OK, I finally got around to doing this with the firmware upgrade cable. I connected the UCM/Pi to the ETH03 UCM and tried to transfer UCMPi7_125.cbf to it.I get the error message "Product number or type does not match". See attached screenshot.
Thanks.Attachment: UCMPi.PNG (Downloaded 14 times)
Posted: Sunday Mar 10th, 2024 01:14 am |
Posts: | 5758 |
From the monitor IO, the UCM is connected by firmware upgrade cable to another UCM, nit UCM/PI. Is this a very old ucm/pi that uses UCM firmware? Canm you do a scan for Modules in the modules tab and send a screenshot of the Modules after scanning
Posted: Sunday Mar 10th, 2024 01:38 pm |
Sota
Posts: | 86 |
The UCM/Pi was connected to the UCM/Eth03 with the firmware cable. Do you mean that I should connect the dead UCM/Pi to the existing UCM/Pi? There is a 6 way connector on it, but no two way connector for the firmware cable.
If I connect the dead UCM/Pi to the system and scan for modules, it appears as a General UCM. When I try to flash the UCM/Pi firmware to it, I get the same error message as before.
Attachment: UCMPi-2.PNG (Downloaded 10 times)
Posted: Monday Mar 11th, 2024 02:27 am |
Posts: | 5758 |
That UCM/PI is actually a general UCM, not specifically UCM/PI as seen in the module scan. I think originally the raspberry was connected to a normal UCM, before the UCM/Pi firmware was produced. Can you take a photo of the UCM pi that you are tring to upgrade?
Posted: Monday Mar 11th, 2024 05:11 pm |
Sota
Posts: | 86 |
This is the UCM/Pi I'm trying to upgrade.
Posted: Tuesday Mar 12th, 2024 03:41 am |
Posts: | 5758 |
That seems to be correct.
You say you are upgrading the UCM/PI by the ucnm/eth03 using the programm9ng cable.
I believe you are using the wrong commands to do the upgrade ie you are right clicking on the ucm/pi module and doing upgrade.
Instead go to Transfer> Firmware Upgrade > By Firmware upgrading cable ...see http://www.comfortforums.com/forum4/1782.html
Posted: Tuesday Mar 12th, 2024 10:11 am |
Sota
Posts: | 86 |
No, I have followed those instructions very carefully. I tried it both ways, connecting it to the UCM/Eth03 with the programming cable and doing Transfer/Firmware Upgrade/By Firmware Upgrading Cable..; and by connecting it directly to the system as a UCM and right-clicking on it to upload a local file.
Both ways give the same error message.
The only thing I notice is that there is no PP2 shunt on the UCM.
Posted: Wednesday Mar 13th, 2024 02:15 am |
Posts: | 5758 |
Somehow the firmware in the UCM/PI was a general UCM. I am glad to hhear that you have managed to upgrade it back to a UCM/Pi
