How to Write Default Tuning Parameters
 Posted: Sunday Jan 8th, 2012 08:31 am
Tuning parameters affect the performance of the Door Station. The  default tuning parameters are optimised for the best performance on Door stations.
If the Comfort system is an older one, the default tuning parameters may not be the same as newer systems
Hence it is advisable to write new default tuniing parameters into Comfort
Please upgrade Comfigurator to the latest version, currently 3.4.0 see forum at http://www.comfortforums.com/forum20/
Connect to Comfort, do File > New and load a default template. DO NOT use your current cclx file which may not have the latest tuning parameters
Go to the menu select Transfer > Write Selective..
Wait for 10 to 20 seconds for the Selective write selection window to appear
Check box for Tuning Parameters and press OK
This writes the default tuning parameters to Comfort
After doing a selective write to Comfort, you need to save the new tuning parameters to your cclx file
Open your cclx file, then do a Selective Read and choose Tuning Parameters. This loads the new tuning parameters from Comfort into your cclx file
Now save the cclx file
 Current time is 08:41 am
