Comfort Home Automation/ Security System Forums > Products > Door Stations > Door Station Problems > Mobile phone voicemail message is heard on doorphone
 Posted: Monday Apr 25th, 2011 10:27 am
dubourg
I have a Comfort II Ultra, version 5.145 with a DM02 door station module interfaced to a Videx audio keypad.
When someone presses the door bell button whilst Comfort is in Away mode, Comfort correctly calls my mobile phone. However my problem is that if I am unable to take the call Comfort plays my voicemail message through the doorphone. This must be a strange experience for the caller!
Should Comfort be waiting for a DTMF tone "0" to be pressed before routing the mobile call to the doorphone?
 Posted: Monday Apr 25th, 2011 11:51 am
You should upgrade the firmware to the current version as some of the issues with Door station voice have been fixed, although I do not recall in which exact version
The Comfort firmware history is on the forum at http://www.comfortforums.com/forum79/
Comfort firmware can be downloaded from http://www.cytech.biz/comfort_ultra_firmware.html
 Posted: Sunday Aug 28th, 2011 10:36 am
dubourg
I have now upgraded my Comfort Ultra to the latest firmware, and I still have the same issue with the door station where my mobile phone voicemail will be played if I don't answer.
Any thoughts on what I should try next?
Tom
 Posted: Sunday Aug 28th, 2011 11:29 am
Playing the voicemail greeting message if the door station has not been answered should be due to the programming
Check Events > Misc Events > Doorbell Response - there should be an action Record Mailbox 1 after x seconds. This causes the doorbell to record a message if the doorbell is npt answered after a programmed duratiion
The new firmware does not wait for a key before switching to doorbell when you answer the call on phone or keypad. It allows you to answer the call quickly intsead of having to press a key
 Posted: Sunday Aug 28th, 2011 11:50 am
dubourg
Thanks for the prompt response,
To check my understanding, what you suggest is that Comfort should be programmed to answer the doorphone to record a message before the time my mobile phone voicemail automatically answers?
If this is the case then it is a work around for me, but not ideal because if my mobile is out of range then my voicemail will automatically answer on the 1st ring. It also presents a security issue for me because if I am on vacation my voicemail will play through the doorphone telling the caller exactly when I return from holiday! Not ideal!
My preference is for comfort to play a message on my mobile advising that a caller is waiting at the doorphone and to press a button on the phone to connect to the doorphone. This gives me a second to prepare to talk to the caller and also the option to ignore it if not convenient.
Thoughts?
 Posted: Sunday Aug 28th, 2011 12:23 pm
There is no option now to wait for a key to be pressed Perhaps we can consider it for the future
I suggest that your voicemail be changed to not to mention that you will be away and when you will be returning. Perhaps just ask then to record a message?
 Posted: Sunday Aug 28th, 2011 12:29 pm
dubourg
Ok understand, my mobile phone is used for business, so it is a professional requirement for me to state my whereabouts.
I'd be very keen to have the functionality to access the doorphone by pressing a button on the phone in a future firmware release.
Tom
 Posted: Tuesday Aug 30th, 2011 04:40 am
That shall be considered, thanks
 Current time is 06:38 am
