Comfort Automation/ Security System Forums > Support > Comfort Installation and Programming Guide > How to Use Comfigurator > Help with extracting programming out of the LOGIC ENGINE CONTROLLER PCB
 Posted: Monday Nov 13th, 2023 10:55 pm
willbeyondzero
Hey guys,
I'm trying to backwards engineer some programming that was left on the logic engineLGX01 by another commissioning ex-employee who has since left.
So far I've been able to connect to the device via the ethernet eth03 connector but as soon as I try to read the logic module I get the following attached error.
Ive also tried to scan for all modules in the configurator application however Í also recieve the exact same comfigurator error.
Do I need to upgrade the firmware or software or something?
I believe this install was done 5 years ago and I am using comfigurator version 3.14.3.0.
If anyone can point me in the right direction that would be much appreciated.
Thanks in advance.
Attachment: error dump message.png (Downloaded 10 times)
 Posted: Tuesday Nov 14th, 2023 12:35 am
Can you uncheck "Optimise Responses" in Options > Settings. Niot sure if this is the problem but please try it.
What other modules do you have in this system?
 Posted: Tuesday Nov 14th, 2023 02:17 am
willbeyondzero
thanks for the reponse,
Yes it is unticked by defualt.
still getting the error.
I've attached the devices connected in the photo.
 Posted: Tuesday Nov 14th, 2023 03:04 am
There is no photo attacxhed?
 Posted: Wednesday Nov 15th, 2023 02:50 am
willbeyondzero
sorry i couldnt attach it,
but theres alot of relay modules that are connected,
I dont want to lose the programming or override it becuase we dont have a backup and the system is quite elaborate.
 Posted: Wednesday Nov 15th, 2023 03:01 am
Can you send the photos top support@cytech.biz?
 Current time is 04:58 pm
