Posts: | 5837 |
You may have an old Comfort I system which has been upgraded to Comfort II. You need to use your old program which was done using Comfigurator 2 and convert it so that it can be read by Comfigurator 3 and to be able to write to the new Comfort II system, without having to rewrite the whole configuration again.
Follow the following steps- Use Comfigurator 3 (always use the latest software version, from http://www.cytech.biz/comfigurator.html )
- Read the old ccl file by File > Open, and select Files of Type ".ccl". Look for the correct ccl file.
- Do File > Save As.. and select Save As Type .cclx. This converts a ccl file used by Comfigurator 2 to cclx format used for Comfigurator 3.
- Your Comfort I system would have a different File System from Comfort II. A File system is the data structure that is used for the data in the Comfort nonvolatile memory (EEPROM). File systems for Comfort 1 are 17 for Comfort I Entry, 18 for Comfort I Pro, 24 for Comfort I Ultra. File Systems for Comfort II are 34 for Comfort II Ultra, 31 for Comfort II Optimum. The File system can be seen on the lower right corner of Comfigurator.
- To convert the Comfort I File System to the Comfort II File System, select File > Convert File System to, and select the file system number from the drop down screen. For example to convert to File System 34 for Comfort II Ultra, select 34.
- Save the converted file under a new name, with the extension cclx automatically appended.
- Select Events > Responses and scroll through the list of Responses. Look for any Response in RED which shows an error, possibly due to a conversion error. If there is such an error double-click on the Response to try to clear it. If the Response is no longer in red, the error has been corrected. If not email the cclx file to support@cytech.biz
- The new file is now ready to be written to Comfort II.
- You are now ready
