Physical Installations of RLY01
 Posted: Sunday Mar 1st, 2015 12:22 am
dellboy13
Does anybody have any pictures of the way they physical installed a RLY01, the relays need to be feed by a MCB, so if you use a common MCB to feed all 4 channels the output will need to also be fused to stop the overload on each relay or you used 4 independent MCB, one for each channel, then you do not need to fuse the outputs. Either way, I would need to build a custom enclosure for the board, so looking for some ideas.
Cheers
Mark
 Current time is 09:46 am
