Posted: Wednesday Nov 18th, 2015 09:50 pm |
evard
Posts: | 23 |
Hi Experts,
I am configuring a Comfort SPC with UCM/ETH03 and UCM/KNX link to Siemens Combi N502/02.
In KNX, I have setup to the Switching module as below:-
0/1/0, 0/1/2, 0/1/4, 0/1/6, 0/1/8 for 5 lights control
0/1/1, 0/1/3, 0/1/5, 0/1/7, 0/1/9 for 5 lights status
In UCM/KNX, I have setup 5 Counters (Counter 001-Counter005) to 1-bit Switching of KNX to get status of 5 different light status (KNX Status Address 0/1/1, 0/1/3, 0/1/5, 0/1/7, 0/1/9).
In Configurator, I have setup 5 Responses to Turn On/Off for 5 KNX Switching (KNX Address 0/1/0, 0/1/2, 0/1/4, 0/1/6, 0/1/8) using 1-bit.
Then, I setup Control menu accordingly to control 5 lights on off and Feedback Type to Counters (Counter 001-Counter005).
It works nicely and I can get the feedback from KNX after switch On/Off.
Then, I want to add a Scene button to Turn All Light Off/On.
So, I created 2 response, 1st Turn All Light On (Execute all the 5 Turn On Light responses), 2nd Turn All Light Off (Execute all the 5 Turn Off Light responses).
When I try to Turn All Light On/Off, I cannot see the status updated to Individual Light control menu. BUT, if I logout and login again, I will see the status updated.
I try to monitor the status in KNX, when I execute the All Light On/Off responses, status are replying from KNX. Which means status is sending back to Comfort.
I check the Control Menu status in Comfigurator, I am getting 0 / 255 after Scene control of All On/Off.
I have tried to Initialized Counter value to 0/255 in All Light On/Off responses, but it still does not show the correct status.
May I know how to overcome this issue? It seems like the Status in Android application is not refreshing after I execute the Scene Control.
Please get back to me as soon as possible because our project is closing soon.
Thank you!
Posted: Thursday Nov 19th, 2015 07:01 am |
Posts: | 5758 |
can you send your cclx file to support@cytech.biz
which android version are you using? make sure it is the latest
Posted: Thursday Nov 19th, 2015 07:21 am |
evard
Posts: | 23 |
Hi slychiu,
I just email the cclx file to support@cytech.biz.
Yes, I am using the latest version.
Thank you!
Posted: Thursday Nov 19th, 2015 07:31 am |
Posts: | 5758 |
Latest version of 2nd generation version 1.6?
Posted: Thursday Nov 19th, 2015 08:49 am |
evard
Posts: | 23 |
Latest version of 2nd generation, I just downloaded from Google PlayStore 2 days ago.
Posted: Friday Nov 20th, 2015 07:14 am |
Posts: | 5758 |
The problem is your Comfort firmware is 6.028 which is 3 years old. This old firmware does not support the android app. The current firmware is 7.078.
ETH03 firmware also needs to be upgraded to the latest 2.16 from http://www.cytech.biz/eth03_firmware.html
For all such projects please upgrade to the latest firmware before starting out. This will save a lot of time.
Instructions on upgrading firmware can be found on http://www.comfortforums.com/forum92/3400.html
Posted: Tuesday Nov 24th, 2015 05:59 am |
evard
Posts: | 23 |
Hi slychiu,
I can get the instant feedback using Scene button after upgraded Controller & UCM to the latest version.
Thank you!
Regards,
Evard
