Posted: Saturday Jun 6th, 2015 09:25 am |
Posts: | 1200 |
The new version 1.5 of the Comfort App for Android Phone and Tablet is now available in the Play Store. Search for "Cytech Comfort". Note that there are separate apps for Android Phone and Android Tablet.
The Tablet app works the same way as the Phone app, except that the Tablet is able to see more of the Control menu on the same page.
Equipment Requirement- UCM/Eth03 Firmware 7.048 or above
- Comfort Firmware Version 7.074 or above
- Eth03 Firmware 2.12 or above
- Android OS 4.0 and above
Improvements (1.5)- Reduced the time for updating of the Control Menu Feedback. This may have contributed to the slow response time reported by some users
Improvements (1.4)- Reduce the time in connecting to the system. The previous version may take some time when trying to connect.
- Fix bug which caused slider bar in the control menu to cause the app to hang
New Features (1.4)- Editable Background in App
- Editable Control icons in Control Menu
- Add "Control Only" function to hide Alarm functions for Automation only applications
- Add Shortcut key "Local" and "Remote" in the login page so that it can be selected without going into Setup
Posted: Saturday Jun 6th, 2015 09:26 am |
Posted: Saturday Jun 6th, 2015 09:27 am |
Posted: Saturday Jun 6th, 2015 09:28 am |
Posts: | 1200 |
The programming is done in Comfigurator. The whole process is divided into 2 parts.
Set up your Android Phone
You must ensure that your Phone is connected to the same WiFi network as your Comfort UCM/Eth03. If you connect to the wrong network you will not only fail to connect but will experience temporary lack of response from the App while it tries to connect to a system that is not there.
By connecting your Comfort system to a WiFi network you are potentially opening up a security vulnerability. Ensure that your Wifi network uses the highest level of security which is appropriate. Accessing Comfort from the Internet exposes the system to additional vulnerabilities.
UCM/ETH03 allows you to select 2 ports for simultaneous connection using Comfort Server Manager
For UCM/ETH03, see instructions at http://www.comfortforums.com/forum113eou/3695.html
Import your cclx file to the App
The zones and Control Menu programmed by Comfigurator are saved as a .cclx file.
The IP Addresses for Local and Internet are also taken from the cclx file.
In Comfigurator, go to File >> Convert cclx file for iOS/Android app
The web link for conversion is also found at http://www.cytech.biz/crl_comfort_app_convertor.php
The conversion website is shown below.
Enter your name in the first box.
Enter an email address that you can access on your phone. This must be an email client and NOT webmail using a browser
Browse to select your cclx file (programming file)
Select "Android" as Target.
Press "UPLOAD FILE" when done.
Posted: Saturday Jun 6th, 2015 09:29 am |
Posts: | 1200 |
Next, in your Email Client, open the email with the title "Comfort Conversion Service". There is an attachment with the extension .jrlccip eg myhome.jrlccip
This is the same name as your cclx file except the extension is changed to jrlcccip.
IMPORTANT - CLOSE THE APP BEFORE TAPPING THE ATTACHMENT, OTHERWISE THE ZONES AND CONTROL MENU ITEMS ARE NOT IMPORTED
Open the attachment by tapping on it, there will be a pop up box "Complete action Using.."
Select "Comfort Mobile".
Note the "Comfort Tablet " is a separate app for Tablets
Then select the configuration to use, click "Default" or another profile name that you have added
Posts: | 1200 |
Open the App. The log in screen is shown below.
The buttons "Local, Remote" will allow you to switch between "Local" and "Remote" without entering Setup page.
Take note of the text "Connected" below the setup and log-in buttons.
"Connected" means that the app is able to connect to the UCM/ETH03. The Login button can be selected only if the status is "Connected"
The profile selected is also shown below and local or Remote connection.
eg "Home@local" or "Office@Remote
If it is not able to connect, the status will show "connecting.." or "not connected" or "data error". "Connecting" means the port is busy ie there is another connection or there is a network problem. "Data Error" probably means that IP address is incorrect
Press the Setup button to go into the setup page.
The IP Addresses and Port numbers for Local and Remote are taken from the cclx file. You can change the IP addresses and port here, or preferably enter these in Comfigurator and re-export into the app.
Select either Local or Remote.
"Local" means you are connected by wifi to the same network as the UCM/ETH03
"Remote" means you are connected by Internet. This requires port forwarding on your router.
The password can be saved (under "demo.dyndns.org" above). If the password is saved here, you will not be required to enter password when you press log in button in LOCAL mode. In Internet mode, you will be required to enter the password.
You can go to Camera Setup page by clicking "Camera" icon (circled in red) on the setup page.
On the Camera side, select "InApp", "Basic", or Pro"
InApp means you can view the camera inside the app provided the camera is in the list of models supported. More cameras wil be added for in app support in future
"Basic" and "Pro" means that one of the 3rd party apps IP Camviewer Basic (free) or IP Camviewer Pro (paid) are used to set up and show the camera. This means that the 3rd party app will take control when you wish to view one of the cameras.
If you select InApp, up to 4 IP cameras can be set up. Select the Camera 1 to 4 and select the Brand and Model from the drop down list. Note that there is a limited set of cameras which are suported in App.
Enter the IP address and Port of the IP camera, and the user name and password for the IP Camera. Check the box "Follow Comforts Remote setting" if the Internet IP address for the camera is the same as that of Comfort (which is normally the case unless the camera is on another network or another site). You can view "Follow Comforts Remote setting" by scrolling down the camera setup page.
Then press "Update>>Done" to finish setup.
Posted: Saturday Jun 6th, 2015 09:30 am |
Posts: | 1200 |
If you do not save your password in setup, when you press log in, you are required to enter your password when connected in LOCAL mode
Slide to the left on the Dashboard page above to view the Zone Status and Alert Status pages
Tap on the button "Security Off" on the top of the page to arm or disarm.
Posted: Saturday Jun 6th, 2015 09:31 am |
Posts: | 1200 |
Tap Control on the top menu to go to the control page, where you can see the state of your lights and appliances on the Control Menu
See http://www.comfortforums.com/forum6/4208.html for instructions on how to program the Control Menu in Comfigurator.
Tap the Camera icon on the top to go to the camera page.
Choose the camera name, eg Axis below.
