Posted: Tuesday Jun 18th, 2024 01:52 pm |
emabonacchi
Posts: | 93 |
Hello and first of all scuse me for my bad English.I am using Cytech Comfort since about 15 years and it is connected to a Pc via serial port because on the Pc is running "Homeseer" software and Cytech is perfectly integrated.Now, i would like do send and receive rs232 data on "Arduino" board rather then "Pc".
I am trying but this seems a little difficult.I have mounted on the Arduino a TTL (with max232 chip) and Db9 Female plug and a "gender changer connector".
If i connect the cable from Cytech to "Pc", i can receive every data, but no data seems to be read from Arduino.Maybe somethink wrong on connection? Or maybe i need to do something i don't know?
Thank you very much.
Ema from Italy
Posted: Tuesday Jun 18th, 2024 02:57 pm |
emabonacchi
Posts: | 93 |
Are the only pins i need to connect "tx" "rx" and "gnd" or maybe some other (handshake hardware)? Maybe i need to invert "rx" and "tx" pins on db9?
Posted: Wednesday Jun 19th, 2024 01:56 am |
Posts: | 5845 |
Yes you need to exchange tx and rx pnm the DB9 so that TX is connected to RX and vice versa
Posted: Wednesday Jun 19th, 2024 05:08 pm |
emabonacchi
Posts: | 93 |
Ok, i will give a try tomorrow.Can you please give me a schematic reporting the pins on Db9 female on Ucm i need to connect and what kind of connection i need to send to thise pins (es. gnd on pin 1, rx on pin 3 etc...)?
I think for example if i open or close a window, some data will pass throught serial port even withouth any ask, is it true? So if i connect cottectly an rs232 cable, i do receive some kind of message opening and closing a window. Right?.......
slychiu wrote: Yes you need to exchange tx and rx pnm the DB9 so that TX is connected to RX and vice versa
Posted: Thursday Jun 20th, 2024 01:02 am |
Posted: Thursday Jun 20th, 2024 05:16 pm |
emabonacchi
Posts: | 93 |
....no success.... I think i am confused in "front" and "rear" view, male or female....
I am trying every changes, but i don't hear signal on my rs232 input..... i know it is my error because on Pc port everything is fine..... i will try and try again.....
Posted: Thursday Jun 20th, 2024 08:05 pm |
strickers
Posts: | 94 |
"no success.... I think i am confused in "front" and "rear" view, male or female"
Its easy the fronts look a lot different
Posted: Friday Jun 21st, 2024 01:45 am |
Posted: Friday Jun 21st, 2024 06:14 pm |
emabonacchi
Posts: | 93 |
No luck.... i am wronging something.
Well, i have an UCM with female Db9 connector. It goes into a Db9 male connector on my Pc and when (for example) a close a windows, some data goes from Ucm into Pc.
I have an Arduino with this female module connected to gnd, tx and rx (and obviusly to vcc in arduino). I have soldered a "male" Db9 to the female pins as described in the schematic but no data traffic into serial monitor.... i am becoming a little crazy because i know it is a stupid problem i can not solve.
Attachment: arduino232.jpeg (Downloaded 25 times)
Posted: Saturday Jun 22nd, 2024 01:00 am |
Posts: | 5845 |
You must set the baud rate to 9600 baud, 8 bits 1 stop bit on arduino
Posted: Saturday Jun 22nd, 2024 08:59 am |
emabonacchi
Posts: | 93 |
This is the default setting for arduino.... speed 9600, data 8bits, NO parity bits, stop bits 1. Last edited on Saturday Jun 22nd, 2024 09:00 am by emabonacchi
Posted: Saturday Jun 22nd, 2024 03:14 pm |
emabonacchi
Posts: | 93 |
Now i have a little suspect. I try to explain (it's difficult because my bad english):
When Ucm is connected via rs232 to my pc running Homeseer, i can open or close a window and pc "hear" data via rs232.So, i disconnect Pc and connect Arduino. Opening and closing the window, no data receive.
If i reconnect Pc, data ok.
I have read on "comfort protocol":
Before the UCM can accept and commands or send status, it needs a valid login. This is done using
the LI login command LIxxxxxx where xxxxxx is a 4 to 6 digit numerical code. If the code is valid,
UCM reports LUnn where nn is a user number 1 to 16 or 254 for Engineer. If invalid LU00 is seen.
E.g. LU09 means Login by User 9.
Once the UCM is logged in commands are accepted and events are reported by the UCM
Well, maybe this can be the problem?
I think no, because when i reconnect Pc, ucm continues to send data correctly even without doing a new login. So, i think it means data continue to way along the rs232.
Am i in wrong?
Posted: Sunday Jun 23rd, 2024 01:22 am |
Posts: | 5845 |
Some data like alarms can go from UCM to PC without a log in. But you need to log inm before the PC can send commands to UCM
Posted: Monday Jun 24th, 2024 04:11 pm |
emabonacchi
Posts: | 93 |
Finally i have had a working result!!
The problem, was only me.... I was in confusion with rear and front, male or female, tx and rx connections.Now, i can easily receive for example "IP0200" when i close a window and "IP0201" when i open the same window as a set of charachters.
Next step, is to send to Ucm some messages.I am not sure about the format i have to send this.I have understood i need to send a STX, a message and a CR.
Maybe i need to send 3 different strings? Or a single string? Or a charachter at time?
In the example <STX>O!1501<CR>, do i need to go in this way?:
Serial1.write("03");
Serial1.write("O!1501");
Serial1.write("0D");
Posted: Tuesday Jun 25th, 2024 01:00 am |
Posted: Thursday Jun 27th, 2024 08:56 am |
emabonacchi
Posts: | 93 |
All ok in receiving data from Ucm, but unfortunaterly no success in sending.
I am doing something wrong, but i don't understand what. I think something about string i send.
Maybe something like "0x03" is what i need?
Posted: Friday Jun 28th, 2024 04:47 am |
17th Post |
Posts: | 5845 |
yes you need to add 0x03 to the start of each command as stated in Comfort Protocol
Posted: Friday Jun 28th, 2024 02:42 pm |
18th Post |
emabonacchi
Posts: | 93 |
Ok, finally everything seems to works fine!
I want to thank you very very very much. Your help was great!
For who wants to use Arduino, the way to send something via serial port is this:
Serial1.write({0x03});
Serial1.write("M?");
Serial1.write({0x0D});
