Leak Sensor?
 Posted: Thursday Feb 8th, 2018 01:40 pm
regnak2018
Guest
Hi,I was looking at the options here but didn't see any mention of leak detection. Has anyone implemented this and is it possible? Thanks
 Posted: Thursday Feb 8th, 2018 01:48 pm
Swiss-Toni
What do you mean by a leak, are you refering to a water detector?
Swiss-Toni
 Posted: Thursday Feb 8th, 2018 01:56 pm
regnak2018
Guest
Yes! I'm looking for a way to detect water leaks to complement the other sensors.
 Posted: Thursday Feb 8th, 2018 05:14 pm
I think Smart Things have a water leak sensor
There are also modular water leak detectors which use a special cable . These can give a dry contact when there is water
 Posted: Thursday Feb 8th, 2018 05:26 pm
regnak2018
Guest
Cheers! I'll check those out....
 Posted: Thursday Feb 8th, 2018 11:37 pm
Swiss-Toni
You can get a basic water detector board which is a open circuit and attach it to a zone if water is present it will trigger any response that you set
 Posted: Friday Feb 9th, 2018 01:35 pm
Swiss-Toni
https://www.ebay.co.uk/itm/5-24V-DC-Water-Leak-Sensor-Detector-System-for-Home-Industrial-Security-DIY/201611430330?epid=2221383166&hash=item2ef0fa49ba:g:hgAAAOSwonBaSG4B
This is a simple water detector I installed in sub floor level works well just connect to a zone!
 Posted: Friday Feb 9th, 2018 02:12 pm
regnak2018
Guest
Cheers. I'm sure someone somewhere put 240vac through it but that looks perfect for my use case (12v of course!). :)
 Posted: Friday Feb 9th, 2018 03:10 pm
Swiss-Toni
If your connecting directly to a comfort system this works, you can also get water sensors that are on a flat pcb board that do exactly the same thing.....
 Current time is 06:44 pm
