Internal Sounder
 Posted: Sunday Nov 11th, 2012 04:29 pm
waynebr
Hi I have eventually managed to safe up enough to order my Comfort alarm and it should be here in the next week. So far I think I am fine with most of the installation but have a question in regards to an internal sounder. When the fire alarm activates I want an internal sounder to sound for a period prior to it sounding external sounder. the keypads will be in a place that may nit be heard easily so have bought a seperate sounder.
Do I just connect this to an output and programme comfort to sound this first on alarm or is there a dedicated section for wiring it to?
 Posted: Monday Nov 12th, 2012 03:09 am
The built-in Speaker and Siren Outputs will sound at the same time
You need to use any Output and program that to turn on the special sounder. You can check Siren Delay in the Alarm Types settings for the alarm type that you want to delay the Siren sounding
The delay time is in Modules and Settings > Siren Delay and is a common setting for any Alarm Type that has Siren Delay checked
 Posted: Monday Nov 12th, 2012 08:15 am
waynebr
 Posted: Tuesday Dec 18th, 2012 09:17 pm
waynebr
Hi can you help with the programming for this. I can see the pulse option but not sure how I do what I need. I need to pulse the siren until the system is reset.
Is there a way of doing this?
 Posted: Wednesday Dec 19th, 2012 02:08 am
The Pulse Output action will send a pulse to the selected Output with a selected Duration. You can use the Flash Output action if you want the output to turn on and off constantly, until a new Output Off action is done to stop it
 Posted: Wednesday Dec 19th, 2012 07:26 am
waynebr
thanks just what I need.
 Current time is 01:57 pm
