Play a recorded message when the doorbell is pressed
When the doorbell (DP03) is pressed, the internal phones ring (RGR04 is needed) and the keypads chime.
You can record a message to play on the door station when the doorbell is pressed.
First create a Response
Select Keypad > Reminder Message on Keypad, Door station or UCM
Select Reminder Message 7 and All keypads and Door stations
This means play Reminder message 7 on all keypads and door sttaions
Or any specific keypad or Door station may be specified.
Next record a Reminder Message (7 in this example) in user menu 2,5 - enter 7# for reminder 7, then 4 for message, press 1 to record the message.  Use an internal phone for better recording clarity. Press 2 to hear the recorded message.
This reminder should not be enabled on the Reminders screen as you do not want the reminder to play at a scheduled time.
In Event > Miscellaneous Events > Doorbell Response, select the Response that you have created.
Now test by pressing the Doorbell. The announcement should be heard on the doorbell/keypads
Instead of a reminder, the Say Words action can also be used. This plays words from
the word list instead of a recorded message
If you want the announcement to be heard on the telephone so that anybody using the phone can hear, go to Modules and Settings and check the biox \"Hear Announcements on telephone\". Note that this will cause all announcements to be heard on the phone momentarily (eg zone announcements)
The example Response is attached in zip form for those who are new to this and which to try it out
Look at Events > Misc Events > Doorbell Response to see the Response which plays the record reminder Message
You will need to record a reminder message on Reminder 1 in this example
Steps;
  1. enter the user menu by signing in on the keypad
  2. Press 2 for Messages,
  3. Press 5 for Reminder Messages
  4. Keypad says \"Enter Reminder message and # key\" Enter 1# for reminder 1,
  5. Press 4 for messages and 1 to record message.
  6. Record your message and press any key to end
  7. Press 2 to hear your message and 1 to record over again if necessary
.zip   PlayMessageDoorStation.zip (Size: 21.75 KB / Downloads: 25)
