The last version of Comfigurator 2 can be downloaded from https://www.cytech.biz/comfigurator_v2.html
Comfigurator 2 should be used for Comfort 1 systems only. Use Comfigurator 3 for Comfort 2
This is a minor version release but it incorporates some useful features which were requested by users; eg comments in Actions, System Information from Comfort saved in the ccl file.
Sunrise/Sunset Responses have also been added
V2.2.3 19/11/2007
Bug fixes
In order to auhorise the use of Engineer code, you need to press F0 on the keypad in order to authorise Engineer Code.
This is a protection from unauthorised access by Installers or other people[/size][/color]
V2.2.3 19/11/2007
Bug fixes
- Fix incorrect upload of alarm type name
- Show Miscellaneous Events -> User Responses as references
- Show Reminders as references
- Fix problem with X10 received responses reverting to housecode A for FS18 and FS31
- Handle Open Door action id as doorstation id, not UCM
- Reminder message on All Doorstations should use id 48, not 32
- Increase timeout for sentence download operations
- Fix bug in editing tuning parameters
- Fix Reminders 9 to 16 On/Off settings download wringly
- Fix Reminders 9 to 16 On/Off settings downloaded wrongly
- Add comment to response action (editable in Select Action dialog)
- Save Comfort version information in CCL file (viewable in General Information screen)
- Monitor window can now be resized and minimised
- Add sunrise/sunset times for Vietnam
- Emphasise warning when attempting to download incompatible filesystem
- Number nondetector alarms
- Add Miscellaneous Events: Sunrise Response, Sunset Response, Door Station Voice On Response, Door Station Voice Off Response
- Sort word list alphabetically in printed worksheet
- Timer 64 causes Unknown Exception Error
- Optimise Responses Option causes Sunrise and Sunset Response to be disabled. Please DISABLE \"Optimise Responses\" in the Options menu
- Entry Alert Response 7 PM to 7AM do Response - does not work
- Sunrise and Sunset Responses do not show as referenced in blue in Responses
- City is not saved in the ccl file for Sunrise/Sunset but the sunrise/sunset times are saved
- When a \"Do Response After Timer\" Action is edited in Response Wizard AND the value of the timer is greater than 255, the wrong Timer name is selected in the drop-down list. When editing, be careful to select the correct timer name before pressing OK, although if you press OK without changing the Timer name, the action code still remains correct
- In Security > CMS, if the Account Code is less than 6 digits, the leading digits 00 are added. eg 4567 becomes 004567. Change using the keypad Engineer Menu 4 for Phone Numbers, select Phone 1 or 2 , 1 for Type CMS, 1 for Monitoring Station Code and enter the account code and # key, eg 4567#. This bug was from Comfigurator 2
