Comfort II Firmware - Flash Versions
Please upgrade to the latest firmware if you are using these firmware versions in order to avoid the known bugs
Version 5.113 (18 Sept 2007)
  • [size=\"2\"]
  • Fix problem for Portugal answering machine where Comfort always answers after 2nd ring even when there is no set-up call. Increased allowed silence between rings from 5.5 to 6.25 seconds and allow for \"phantom\" ring before 1st ring
  • Fixed problem where a complete Vocabulary download tends to stops at sentences. However Sentence download by itself may not work sometimes, but will always work on 2nd attempt
  • Default power on date is 18/09/07
  • Fixed bug - saywords action causes system reset.
  • Fixed BUG sunrise and sunset times did not adjust for daylight saving causing sunrise and sunset to be 1 hour early during Daylight saving
  • Introduced Sunrise and Sunset responses for OPT and ULT file systems. FS34 Sunrise Response at Location 776/777, Sunset Response at 778/779. For FS31, Sunset at 1696, Sunset at 1697.
  • Fixed BUG when Daylight time is to be changed that day, the adjustment forward or backwards is made at the very next hour regardless of time, instead of at 3 AM[/size]
[size=\"2\"]Known  Bugs[/size]
  1. [size=\"2\"][size=\"2\"]
  2. Zone 64 does not work
  3. Baby Monitor and KP menu 5 for Voice station does not work
  4. X10 receive does not work
  5. Battery disconnect detection does not work with very low low current. Requires some time before battery disconnect alarm occurs
  6. Within the week of the Daylight Saving Time change ie sunrise and sunset times occur 1 hour later within the week of the DST change
  7. AGC and intercom tune parameters do not work
  8. Using local phone when arming, pressing * to abort can hear user menu on KP.
  9. LCD text download sometimes does not work - causes Sync message again due to checksum error
  10. LEM03 zones 17 to 24 are not shown on KP04 LCD.
  11. DA command to UCM does not work for SKIP action
  12. GSM Line IN Gain (Parameter 52) does not work
  13. GSM dialing to 2 phones - at 2nd phone dialout when user terminates \"goodbye\" the call may not be ended
  14. GSM dialout to CMS does not work in Comfort II
  15. During Remote phone access Via UCM/GSM, a false line cut is detected and causes the call to be ended.
  16. Action 88 - Do Alarm (User) is not recorded in the event log
  17. Week 53 gives wrong Sunrise/sunset Times
  18. CMS Dialout to Portugal times out
  19. Dialout via UCM/GSM2 to CMS does not work
  20. Intercom parameters not optimised
    [/size][/size]
Version 5.106 31 August 2007
  1. [size=\"2\"]
  2. Fixed Bug after erase the only New message, the menu says \"Day 8 PM\" after \"message erased\"
  3. Sunset/Sunrise times and Daylight savings implemented
  4. Fixed bug which caused wrong announcement after ring detected
  5. Set default DTMF gain in Test Mode
  6. UCM Sensors Report implemented
  7. Fixed bug in OPT - If Invalid O/P addressed, partial message is corrupted spoils the next message eg if OPT asked to set O/P > 16, next message is corrupted
  8. RS485 Receive amnd Transmit buffer sizes increased
  9. Allow deeper nesting of Do Responses
  10. Fixed check of min and max recording AGC gains
  11. Fixed bug where incoming call answered, but caller hangup immediately before sign in announced, UCM/GSM does not send connected and call ended status as it is connected and ended within the same period polled by the UCM/GSM
  12. Fixed problem when UK. dial tone is heard when caller hangs up. This causes record task to end without ending the recording properly and setting the new message flag hence the MSG LED does not turn on
  13. Mute KP Mic during system announcements so no chance of mic picking up sounds during KP announcements
  14. Changes to work with better with Comfort I SEMs
  15. Fixed BUG VS sentence download may fail at the end when v! is entered because system resets too fast.
  16. If file system mismatch and default 1234 allowed as User 1 and 6789 is allowed as Engineer code for UCM login, dont care if engineer code not enabled so Comfigurator can login.
  17. Average input samples for Main Board and LEM over 50 Hz to reduce AC induction effects from power supply disturbances
  18. when announcing on keypads or in in security check , and no detector triggger, say null sentence so that Record Gain set to max will not result in buzzing noise on keypad
  19. Fixed occasional problem when arming security check beep may suddenly become louder every cycle because of speaker switching
  20. When arming, any 24 hour or tamper alarm will announce and exit from arming. The intruder alarm siren will come on and Armed led will flash
  21. When arming and Slave comms failure causes Tamper alarm, announce Tamper alarm and exit from arming state.
  22. Security update armed leds regardless of arming so that any alarm during arming will show flashing red led.
  23. When Slave has comms failure,all its zones will have Trouble state, but will not report as individual trouble alarms to avoid having many alarms at the same time. When the system is being armed the slave zones will be reported as trouble and hance can be forced armed
  24. When system reset when it is armed, automatic re-arm to previous mode now has min 15 seconds delay (Night Exit time) so that the slaves have enough time to initialse and report their zones to avoid alarm after system armed
  25. Night Exit Time minimin is 3 seconds to avoid too short delay for Night arming and auto arming especially after reset. Shorter night exit time than 3 seconds will result in 3 seconds night exit time
  26. Delay to confirm phone offhook during dialout changed from 500 ms to 1 sec to prevent false detection of offhook causing many repeat dial attempts
  27. Fixed BUG reminder dialout gives wrong user no for event log reporting
  28. Fixed bug for answering machine cannot answer calls when PABX or VOIP line is used.
  29. Event Log added Erase Messages event. Parameter is message tag for messages to be deleted. Event announcement is \"Messages Erased\". Event Log Upload will show message tag as parameter
  30. Fixed BUG when arming and ID tamper occurs and restored, there is alarm but system continues to arm and when door is closed the system arms.
  31. When KP menu comes on, turn on keypad backlight. \"Thank You, Goodbye\" turns off backlight. KP firmware will change so that when backlight ON command is received the keypress will not turn off backlight after 10 seconds. To avoid situation when in dark using keypad the backlight turns off in the middle because of keypress
  32. KP query for hide alarms/show alarms status reply was fixed
  33. Event Log (EN50131) : Ultra increased from 250 to 600 events. Location of event pointer in eeprom has been changed. To upload event log, require Comfigurator 2.1.1 and above whch uses E? Command instead of the eeprom location. When the firmware is upgraded, the event log is lost
  34. EN50131: Show Alarms enabled for Ultra See en50131 implementation document.
  35. GSM – Fixed situation where calling to GSM sometimes does not connect to GSM but line is connected. Happens for some networks where connection status is longer than 4 seconds (eg Starhub). Delay time to accept call was increased to 9 seconds. UCM with
  36. GSM - fix bug where if gsm takes exactly 5 seconds between command to accept the call and status connected, the timeout and end call is sent at the same time as the gsm connected status from UCM, and when next call comes, the call is not accepted but caller does not know and line remains connected. Starhub takes 3 to 4 seconds sometines 5 to accept call, singtel takes 2-3 secs. GM47 is faster to accept call than GR64 so problem occurs for GR64 and starhub combination.
  37. Event Log: Event log message for keypad and UCM format kept to 1 byte even though > 256 events. The NN event log index is max 254 to maintain compatibility with old keypads and ucm
  38. EN50131; entrydialdelay bit 1, Location 42 to determine dial delay in entry alert for En50131 (see EN50131.lwp) for implementation. In Entry warning alarm, start a dial delay for 30 seconds.
  39. For Battery Test, send command to Slave to do its own battery test independently for the same duration as master. In previous versions, the Master did not send the slave battery test command. Old Slave firmware < 5.082 does accept the slave battery test command but the slave battery test is ended if Master has a low battery.For Slave 5.082, Slave will do an independent battery test and will not end the battery test when the Master has a low battery condition during the test
  40. [size=\"2\"][size=\"2\"]Week 53 gives wrong Sunrise/sunset Times[/size][/size][/size]
