Threads: 32
Ok, do I have to buy the whole UCM, or is it possible to just buy the \'daughterboard\' that sits on top?
Threads: 868
1
You can buy the GSM daughterboard instead of the whle UCM. Sometimes after a long time in use. there may be problems with the 10 way socket, so I am often reluctant t6o recommend this
Threads: 32
I\'ve now received formal notification from my provider that they are imminently switching off 3G and leaving only 2G (for calls & test only, not data), plus 4G and 5G.
As I believe Comfort only uses voice and SMS I assume it will fall back to 2G and continue to work okay, so I will not actually need to upgrade my UCM. Is that correct? They might have even done this already in my area, it isn\'t very clear, and Comfort GSM is still working.
Although I have been getting some oddities lately (such as trying to dial in and being repeatedly told I\'m entering the wrong code) - usually only when in an Alarm condition, as when I get home and test everything works fine. I should probably force an alarm and test again and then start a separate thread about that.
Threads: 868
1
That is correct UCM/3G should work in 2G. But support for 2G may not be so good by some carriers leading to some of the sign in problems that you have experienced
Threads: 868
1
In fact UCM/4G does fall back to 2G (GSM) at 900 Mhz/1800 Mhz frequencies. We have not tested connection with 4G and voice on 2G, as we have not had 2G for some years.
We are planning to develop a 4G module with VoLTE by the end oof the year (hopefully)
Threads: 32
Ok, thanks, good to know. I\'ll hold out for a VoLTE compatible module then and upgrade at that point
Threads: 32
Any update on the VoLTE module yet?
