The UCM/4G GSM Module is able to synchronise the Comfort Time with an Internet Time Server
Go to the Modules Tab.
select the UCM/ GSM Module on the left pane. On the right pane see UCM/GSM Properties. Set \"Time Update from GSM\" value =1.
For Time Zone, enter the hours offset from GMT, eg 0 for UK, +8 for singapore.
WRITE to EEPROM on the top menu of the GSM Menu
Note that the UCM/ETH03 has a similar feature. If you also have a UCM/ETH03, use only 1 of the time sync features on 1 of the modules to prevent unneccessary time updates from the NTP server
This feature is not present in the UCM/GSM 3G module
