Comfigurator losing EOL setting
Using Comfigurator v 3.13.7.0 to program a recently upgraded system with a CM9001 board, which has the EOL settings programmed, rather than as hardware shunts.
I find that, quite often, Comfigurator loses the Double EOL setting and reverts all zones back to \"No EOL\", which is a problem if I don\'t notice it\'s done this, and upload the configuration, only for the system to erupt with Tamper alerts.
I\'ve not yet worked out what sequence of usage causes this.
Cheers,
Keith
I have not encountered this.  It may be doe to scanning for modules not getting the correct info. Defaulti s Shunts. Watch out for this after log in as there is an automatic scan for modules
Yes have experienced this on many occasions
I expect that pressing the update defaults button will fix it !
