Threads: 4
Hello,
For several days I have encountered a problem. I no longer receive text messages. If I still send an arming order by SMS, nothing happens. I presice that my system is working perfectly through the application.
So I am going back to comfigurator. I updated the whole installation but still nothing. I also tried with a second sim card. In the status bar it appears \"Unknown GSM Module\".
Can you help me solve my problem?
Threads: 885
Unknown GSM Module means that the GSM Module is having diffculty connecting to the network provider.
Try powering off the module.
What is the serial number?
Threads: 4
Hello,
I confirmed that I had tried to turn the system off and back on. I changed my SIM card from another provider. No change while my phones are picking up correctly. the serial numbers are P081808 and P081820
SIM900
S2-1040S-Z0912
SN:MP0610512267627
What can I do now?
Threads: 885
This is a 2G GSM Module UCM/GSM4(2G) sold in 2013.
Many countries have stopped supporting the 2G network. It may also depend on the network provider. Have you upgraded the gsm submodule to 3G?
Threads: 4
Hello,
According to my research, the 2G services of my provider are still active but without certainty. What is the procedure to update my module?
regards
Threads: 4
Hello,
I finally have an answer from my supplier who assures me that 2G is still active until the end of this year. I plan to change my module in anticipation but where could my worries come from if 2G is active? I would like to be sure before. Thank you
Best regards
Threads: 885
You can buy the UCM/GSM 3G which will work on 3G networks. Check that your home is supported by 3G
Threads: 885
iF it is not a 2G problem, it may be some fault with the module, the 2G submodule or the UCM. You could but just the 3G submodule, and if that has a rpoblem, get the UCM/GSM base board separately
