08-03-2020, 01:46 PM
I have a Comfort II with a Z-wave board. I know Z-wave is being phased out - but when its working it works well for me.My Primary Z-wave controller is HomeSeer software. Comfort is a secondary controller.
I have over 40 Z-wave devices some of which are virtual devices created from Comfort.I recently added a couple of new physical devices using the primary controller. They appear and function as they should.I did a \'Learn\' in Comfort so I could uses one of the devices in a Response.The 2 new devices appeared following the LearnHowever - when I go to try and program a response the Z-wave action only shows the Basic Get Command, the Set Command is not available.Not only is not available for the new devices it has disappeared for all devices!The devices still work and I can control them using the ON and Off switches in the Z-wave mapping window.If I go back and load an earlier CCLX everything is back to how it should be!I have tried \'re-learning\' but each time the same thing happens.Any ideas or suggestions are welcome.
