Threads: 1
Is their anyone that can help me with this problem i have with my alarm.
It\'s displaying Wrong Text, Press 1 to sync. And if you do this the alarm freeze.
Eugene
You have to press * and 1 together and not 1 alone. The system should be fine after the downloading.
Threads: 1
I have pressed the * and one at the same time, but then the panel freeze.
But i have also used the same keypad on a other Comfort pannel and if you press * and one at the same time it works fine.
But way can\'t i do it with this one pannel?
Eugene
Threads: 476
Which Comfort model you have and what is the firmware version written on the U1 label?
Other than the keypad message, does the keypad work when you enter your code to sign in? Do you hear the comfort voice?
Threads: 8
Hello, I\'m having the same problem. After pressing *+1 the panel frezzes.
The U1 firmware version is 5.045 (OPT)
Thanks.
Threads: 262
Does the keypad ask you to \"Press *1\"? The older keypads which work with Comfort I do not do that. firmware 5.054 needs to be replaced by a new firmware. it was announced elsewhere on the forums.
Can you private message me and let me know where you bought the system from so we can arrange an upgrade for you
