Threads: 50
One of my two KP04 (version 1.017) stopped responding to keystrokes about 4 days ago.
It constantly shows the ID# and Version on screen.
I have Comfort Ultra (7.160).
The other KP04 as well as KP06 are responding without any issues.
Threads: 885
THis meams thet Keypad is not connected to the Vus. There may be a wiring problenDo you see \"No Bus Commun9cation\" or \"ID Not Polled\"?Power off and on the keypad again
Threads: 50
The screen is consistently showing the ID# and version. Nothing else shows on the screen.
I can however see the keypad from Comfigurator and I have coded the back-light to come on when there is movement in the hall, and it is still doing that, which suggests there is communication.
Threads: 885
Can you enter the code on the keypad to hear the user menu?
Threads: 50
There is no sound coming from the keypad.
Threads: 885
It is probably due to a conflict in IDcheck what is the ID displayed and whether it is the sae as other keypadsThe ID shunt may have fallen off
Do you have a Communications failure alarm ?
Threads: 50
ID#2 is displayed, which is the correct ID, (ID#1 and ID#3 are the other 2 keypads).
There is no communications failure alarm.
It seems day and night arm keys are working, as it the alarms arms accordingly, but there is no feedback (visual or sound) from the keypad.
Threads: 885
try swapping the id of this keypad with another keypad, so that oth keypads swap their ids, and see if the fault goes with the ID or with the keypad
Threads: 50
I was travelling so did not get a chance to physically change the IDs. So this past weekend before attempting to do the change, I updated the configuration with Comfigurator and that seemed to have resolved the issue.
