KT03 - upgrade failed
I\'ve just been upgrading KT03 they take best part of 1/2hr when over the bus rather than USB direct !
Unfortunately the laptop im using went to sleep during the firmware upgrade and now the KT03 is dead -
Can I still upload via the USB on the front?
When an upgrade fails for any reason, always do the upgrade again using the same method. In your case I assume by UCM. Doing by USB after it fails will not work, unless it was done by USB and failed
A faster way is to use the UCM Programmi9ng Cable. Use a UCM and connect the firmware programming cable to KT03 This is much faster
see
http://www.comfortforums.com/forum4/1782.html
