Threads: 189
If you are working with responses for any length of time or with any number of responses it become very annoying having the responses screen jump back to front page or top of list every time you carry out an action.
Can we add to the wish list that the responses screen remains at the last used position after a save or alteration or jump to another window.
Threads: 868
Noted, we will see if that can be changed
Threads: 868
Actually, where does this happen?I just tried to edit and add responsesWhen finished, the edited or added response is in view. The screen does not jump back to the topShow the sequence of what you do so we can duplicate
Threads: 189
Thanks for noting
IN 90% of instances on my WIN10 laptop.
once you have altered a response click enter you will find the main cursor jumps to top of responses page.
occasionally it will stay with the response you have worked on BUT manages to put the highlighted response one line up from the bottom of the screen ( which is nearly as bad) - ideal location - highlighted last response worked on in middle of page.
Note when I\'m programming i will name everything by category so if for example its a KNX related response to switch lights ill name it KNXHallLight so when im working the columns are always SORTED so responses appear in alphabetical order.......
Threads: 189
Thanks for noting
