I want to have two away modes. One with all sensors active and one with a pir off. Dogs in the house. I know I can disable one but thatââ¬â¢s a lot of button presses. Ideally I would like the day button to be the same as away but one pir off.
Threads: 868
You can use Day mode for the one where the dog is in the houseAsign the PIR as a zone type 5 which is Immediate in Away and Night ModesWhen you arm to Day, the zone in zone type 5 will not cause alarm
However when you arm to Day Mode, you are not required to exit, so the system willl arm after the Night Exit Time (default 5 seconds) even when tyou are in the house
Another method is to reprogram the Day Mode key to another Response, as all function keys can be reprogrammed in Control > KeypadThis new response is Bypass Dog zone, then Key arm to away
