11-26-2018, 06:28 AM
Surely its time to update or revamp the comfort app!
Its looking and feeling beyond tired now - whats the plan !
Comfort app NO NEW developments planned
11-26-2018, 09:22 AM
How would you change it, what improvements would you make to it?
11-26-2018, 09:58 AM
I understand that the android and iphone are possibly different we have mainly dealt with the android.
Set upOn several android screens the set up gets to a point where everything is filled in and you are unable to proceed ( the save screen is hidden) The structure..Primarily its and ap for arming and disarming your alarm. So the structure should reflect this.In a most basic set up I don\'t want customers to be able to access pages that either have no relevance or do absolutely nothing. Home automationThe screen reflects the comfigurator tiered home control menu and I can accept this, although not ideal. Would it not be great to have a simple on off button with feed back for say a light circuit or lighting scene! This would be a start. Then categorize by function or geography so sort by room or sort by function e.g. lighting or blinds or heating. We deal with a number of different manufacturers and this is all standard format now and has been for several years. Overall Comfort is simply looking tired, its an amazing product but the front end is and always has been .......... well at best not good!
11-29-2018, 09:59 AM
Any comments form Cytech appreciated.
Perhaps an action plan or idea of development schedules for this activity?
11-30-2018, 06:01 AM
I suggest you look at the UCM/Pi under testing now. This has many more capabilities than the cytech app
I suggest to get involves in the 2nd beta phase as announced here http://www.comfortforums.com/forum136/4988.html
11-20-2019, 04:35 PM
(This post was last modified: 11-20-2019, 04:36 PM by Swiss-Toni.)
I have come across an issue with the Android App, it no longer works! The ethernet connection works with comfigurator so I have to eliminate that from the equasion
The ip address are all correct However it will not connect via the local network or the Internet All the setting are what I have used over the years with this system obviously updating WAN address when required Also port forwarding has been setup correctly, The only thing that has changed would be firmware and software upgrades Down graded both but still not working. Any ideas anyone
11-20-2019, 09:12 PM
If someone is going to assess the app it need a redesign!As per post of a year ago
11-21-2019, 02:20 AM
What error message do you get?
Does it not connect or you cannnot log in Conections is the same as Comfigurator If comfiguaror is able too conenect then so should the app
11-21-2019, 10:11 AM
Managed to resolve the issue, I was of the same assumption if you connect via comfigurator it must connect.
The result was that there is another router on my network which replicated the IP address causing the conflict, hence I was unable to connect via any other method other than by my PC hardwired to the network. |
| 2 Guest(s) |
