Threads: 34
I have 4 keypads two of which are KP06. One is KP06 and the other KP06A.The KP06A was fitted recently and the number 9 does not always activate when pressed unless pressed more firmly that the others. Can I swap the small keypad module from the KP06 to the KP06A to test if it is the small module or the whole keypad that is at fault?
Cheers
Ian
Threads: 888
The keyboard module can be interchanged between KP06A and KP06The LCD modules cannotIf the KP06A keyboard has a faulty button it can be replaced if you confirm
Threads: 34
Thanks. I will do a swap and test when I get back.
Threads: 888
Can you check with the distributor if they have a spare keyboard module?
Threads: 888
Can you send an email to support@cytech.biz? with yoiur name, and address and contact number
we will replace the keyboard directly. Is it white or silver ?
Threads: 888
The replacement module has been sent out
