UCM 7.109 - 7.119
The beta firmware has the following improvements and bug fixes;
  1. Bypassed zone now report in z? reply as OFF not on.
  2. Prevent f? flag states Report and SN report at reset without login
  3. UCM sends Cs01 if ID is not polled, sent Cs02 if there is no RS485 communications.
  4. U? add last byte 00 for non eth03, 01 for ETH03 This is to allow comfigurator to know if ETH03 is installed in future
  5. Fixed BUGs - sometimes  UPLOAD and DOWNLOAD buttons on UCM did not work.
BUG !!
  1. causes Vocab Upgrade to fail at 23%, 50%, 75 %
  2. COPY Button set ID could not set to maximum 8 From UCM 7.072
A bug may have been identified in UCM 7.109. It may cause Vocabulary Upgrade to Fail at certain completion rates eg 23%, 50% etc
UCM 7.109 has been withdrawn and UCM 7.098 is the latest release
Please downgrade to 7.098 before doing any Vocabulary Upgrade
UCM 7.110
Fixed BUG from 7.109 - Vocabulary Upgrade sometimes fails at 23%, 50%, 75 %
From UCM 7.110, the EM100 (Tibbo) ethernet module is no longer supported. Pleadse change the submodule to ETh003 or do not upgrade to 7.110
UCM 7.119 (23/3/2019)
  • UCM/cbus2 Added Custom applications 1 and 2
  • Fixed Bug E? Event log command E?FFFE FFFD did not work
  • Fixed BUG send DA 197 command. Do action 197 send text to rs232 did not work. BUG from 22/12/17 UCM 7.110
  • UCM/Universal transmit delay 600 ms between transmit. Found that some devices transmit too close together did not work (Dunkley)
  • RD command if id = 01 and eeprom=0 dont read from self eeprom
  • Reversed 11/6/18 change. caused RS11 to be sent only after UCM login so cannot log in 1st time
  • Improved Cs01, Cs02 time outs sequences
  • Fixed Bug Cs01 and Cs02 do not cause ETH03 to hang
  • Restart RS485 comms timer when any character is received so that if comms lost after a complete message is received before the next STX, the comms will time out.
  • Fixed BUG sent wrong value for alarm state ie S? gave alarm type
  • added ?? command to reply CsNN
  • after Bus communication is lost and UCM sent Cs02, when bus polling restores, dont send Cs01 before Cs00. Send Cs00 when id is polled.
  • Fixed bug from 27/6/15 7.072 COPY switch ID could not set to max 8
UCM 7.117
  • UCM/Modbus allow each Modbus to comfort Line to have different Modbus ID
  • UCM/Universal alternate product type = 27 modbus allow universal to upgrade to Modbus
  • Universal UCM  fixed BUG when message has terminator, compare failed because terminator is saved in buffer, and compared with device to comfort string which is without the terminator
  • Fixed Bug in Modbus. Output from Comfort trigger counter to Modbus. Made UCM/Modbus 7.117 and  Ucm/Velbus 7.117
