01-07-2018, 12:24 PM
(This post was last modified: 01-07-2018, 12:44 PM by Swiss-Toni.)
[font=\"times new roman\"]I am just toying with an idea and wondered if you have come across anything similar. I am looking at using micro sensor (undecided which ones I will use) on metal railing gates for pathway and drive way which would be direcly connected to comfort zones covering two purposes, firstly to act as a perimeter warning and secondly to control front area lighting. My question is what sequence would you use to send a signal to ST and then in turn that could turn a smart TV on to a hdmi port for the CCTV? PS At present I am asuming that you would use Zone monitioring in ST with a command attached! However I was wondering if this could be short circuited by having direct control from R-PI (as you maybe aware I am not a great fan of any cloud based systems). [/font]
