I might be swapping out my door station for a new VOIP video one (probably am)
I currently use the door station to make a momentry connection to my gates to open them.
Assuming this goes - Do I need a relay? Or can I just use one of the OP connections straight off the board? In my case it would be the slave in the garage. (Either way, how do I work out which OP it is to programme in Comfigurator?)
My gut feel is is I will need a little relay....
Stuart
Stuart
