12-06-2017, 06:20 PM
following on from the thread here,
Can I add the following request to comfort programming (so comfort and Comfigurator I guess):
- the ability for a response to check which holiday is active (if \'holiday\' were an integer rather than boolean it could hold the id of the holiday entry that has set it)
- if possible the ability to set a period (eg 5 days) or end date for a holiday entry
It would then be possible to check which holiday entry is active.
Can I also add the following requests for android app please:
- can you add the same show timer / camera checkboxes as are now in ios app,
- can you make it possible to configure the holiday entries, so they can be set without needing reprogramming via Comfigurator
Many Thanks.
Many Thanks.
)Add to this, during our summer holidays we have a chap come and mow the lawns and paddock. He needs different access, so I could set a different holiday.
Or maybe all I need is for partitions to work differently...
