11-04-2017, 10:49 AM
HIO Firmware 7.023 supports the new 5V CPU
Previous versions 7.00x were for the 3.3V CPU which has been superceded
Changes
Changes
- Added 3 more Master scenes (ie. Total 4 Master scenes now).
- Added new sequence scene function. With each pressed, a different scene is activated, starting from scene 1 to 4 and back to scene 1.
- Added new 1-button Blinds function with 2 outputs. The first output is for Up direction and the second output is for down direction.
- Fixed temperature reading giving 255 (FFh) for some boards, when TS input is shorted to ground. Correct reading is 100 (64h).
