Threads: 29
I have a strange issue with my system.
When someone leaves a message and I replay it the date/time stamp is corrupted.
For example I would hear something like this, rather than the hrs/mins.
\"Wednesday Wednesday Wednesday PM\"
Any thoughts.
Threads: 888
This may be due to the sentences being corruipted
Try doing a Sentence Tale upgrade, and select the latest vocab file
Make sure you comfort firmware is up to date, as some old versions had a problem with sentences upgrade
Threads: 29
Oops I think I went a bit wrong!
I just did a Vocab Upgrade (using kate39.bin) and now the words seem to be all mixed up, i.e. the prompts are all wrong via the keypad/communicator!
Threads: 888
did the vocab upgrade complete successfully?
what does the Transfer> system information screen say
Threads: 29
The transfer seemed to work ok (it did stop near the end and ask me whether I wanted to start from where it stopped, which I did do).
The System Information screen says:
Firmware Type: Comfort II Ultra
Version: 7.116
File System: 34
Vocabulary Number: 5
Custom Vocabulary: No
System Vocabulary Version: 39
User Vocabulary Version: 1
LCD Text Version: 2
LCD KP Minimum Version: 3
For reference the system says \"Seven Zero Alert\" when I exit the voice menu with the F key, rather than \"Security Off\".
Threads: 888
System info seems to be correct
Can you just do a Sentences table upgrqrade instead of the full vocab upgrade
Threads: 29
I tried that too, and no change.
I\'ve also just tried myma39.bin and I still have the same issue.
Threads: 888
It appears like some fault on the comfort unfortunately
I have not encountered that before
When was it purchased, do you have serial number?
