I have a Comfort II with zman3.My main zwave network is controlled by HomeSeer.
My front door has a wired open/close sensor direct to Comfort. It works fine and I can trigger responses within Comfort.
I want to be able to use the front door opening to trigger responses via zwave in the HomeSeer system.
I set up a virtual input in Comfort using HomeSeer as the primary controller.
I then set up two responses, open and close. The responses are \'VirtualInput VirtualFrontDoor On (and off). I have set these as the on and off response for the input that is real front door
When I open the real Front door the virtual front becomes \'active\' in Comfort but when I close the door it remains active!
So is the way I am trying to achieve what I want the best way?
And - what would be the best zone type to set the virtual input to?
Cheers
Cheers
