Threads: 31
Thankyou for your responce, that was what I was doing!I have found that the IR will not work with my LEM01 and had to move it to No 16 Output in the main panel and it worked as it should.
Is their any known issues with using IR conected to Outputs beyond output 16?
Prior to putting it on Output 16 I tried to have connected to Output 21.
Threads: 868
1
Output 16 is on LEM01 not on main panel
Output 21 should be on the Slave (SEM)
Do you mean it could not work on the SEM? what is the firmware of the SEM?
Threads: 31
12-10-2016, 03:45 PM
(This post was last modified: 12-10-2016, 03:52 PM by Swiss-Toni.)
I stand corrected, It does not work on the SEM the firmware version is curently 6.068
(Also Output board working fine with relays)
Threads: 868
1
There should be no problem with SEM 6.068 sending IR codes
Can you send your cclx file to support@cytech.biz?
Threads: 31
Hi SlyChiu
I noticed quite a few issues on my system where the IR was concerned and downgraded the use of comfigurator until it was working fine, Although admittedly I have not moved the IR back to the SEM as everything is working (if it isnt broke dont fix it rule) Not sure what was causing the issues as KT03 (the output signals)keypads were affected as well, I think there must have been a corrupt file somewhere along the line.
Threads: 868
1
Saved Infrared Codes may be found in the folder C:\\ProgramData\\Cytech\\Comfigurator\\ifr
