05-29-2016, 07:22 AM
IRIO Firmware 7.004 has the following changes
see http://www.comfortforums.com/view_topic.php?id=4458&forum_id=20
- Added Temperature Sensor Function function to submodules ISM01, ISM07. This requires an external TSM01 Thermistor and allows mapped sensor to rad the temperature.
- Added Resistive Sensor Function to submodules ISM01, ISM07. This caters for any resistive type sensor eg Light, Pressure etc to be mapped to sensor.
- Added IR with Feedback Function to ISM03 Infrared submodule which uses Current sensor as feedback for the IR controlled device
- Current sensor function added Mapping to Sensor as additional to Flag so the Sensor can be used to determine the current sensing level
