Threads: 14
Hi Chiu
In the UK if you don\'t use your Pay As You Go sim card for about 3 Months the card is cancelled by the operator.
So if your Comfort system is working well, there is a distinct possibility of the card being cancelled.
If Like myself I only use the GSM module to inform me of fault or actual Alarms there is a likely chance that I would forget the 3 month limit, and then No GSM dial out.
Would it be possible for a text message every first of the month (selectable in set up)
Thanks in advance
Mike
Threads: 871
Yes you can use Time Programs
Create a new Time Program
select a Day of week eg Monday and a time to send your sms eg 12 PM
Remember to Enable the time program
Click on Response Name, select New and create a new Response for the time program
If Day = 1 Then
AlarmUser CMSTest
End If
This means If Day of month = 1 then do alarm CMS Test
Go to Security Types > Alarm Types > CMS test to select which phone to send the sms to
I prefer to send an SMS every day or when the system is armed and disarmed
Threads: 14
Thanks you again Chiu :-)
Threads: 31
04-10-2016, 09:18 AM
(This post was last modified: 04-10-2016, 09:19 AM by Swiss-Toni.)
You dont seem to have this problem with GiffGaff payg sim cards and they do keep you infomed by email of the status of your account. Also to send a text it cost only 5p as of 10/04/2016
I always recomend them on any installations that I have done and use it on my own system (admittedly a message is sent frequently for side gate being openend when alarm is on Armed/Night mode without activating alarm)
Threads: 219
04-10-2016, 04:48 PM
(This post was last modified: 04-10-2016, 04:56 PM by juwi_uk.)
I had a Vodafone PAYG and that definitely pulled the plug after a while of non-use. Thing with this is then the number is disabled and you cant get it reactivated.
In the end I\'m now on a ã5 a month contract with Virgin Media for this now though who knows maybe I should go to GiffGaff if that doesn\'t disable and save myself ã60 a year!
Ju
Hi, I have a system I purchased some time ago, but just installing now and I wondered if there was an update on this topic since 2016.
I have a UCM/GSM2, I live in a rural area with patchy 3G/4G connection but a decent Vodafone signal. GiffGaff not a great option as they use O2 and in general monthly plans for Vodafone SIMs seem to be based on 4G/5G. I see its possible to have Comfort send regular texts to avoid cut-off, but how do you manage a pay as you go SIM - i.e. how do you know when it needs to be topped up?
Threads: 871
Unfortunately for PAYG, there is no standard way to know that the simcard is running out of money. ie the module cannot interrogate the network or the card. Normally there is a voice message after evenry call which tells you the balance, which is not helpful. So you will have to top up regularly. Are you sire there is still a 2G network? as the UM/GS,2 will not work with 3G
Ok, thanks Chiu. I better check if there is still a 2G network, though ultimately it sounds like I\'ll need to upgrade the UCM/GSM and go to a monthly plan, if that\'s the only way to see what balance is on the SIM card.
