12-22-2015, 01:24 AM
(This post was last modified: 12-22-2015, 01:31 AM by wexfordman.)
I had a dvr which had a relay output which I used to trigger a comfort response based in motion detection via the dvr.
It worked great as you could realy tailor actions based in where specifically the motion was detected. One drawback was the dvr only had one relay output, so I could only relay have one comfort response for the whole dvr.
Most dvr are the same and have only a limited number of outputs, however, they all have email sending which means you could send multiple email headings to indicate lots of different actions required.
If co fort had the ability to perform a response based on an email receipt and its heading then the options are unlimited, and it would be a very straightforward interface to configure.
100% of dvrs have this feature, so comfort would instantly be able to communicate or interface with sherry single dvr type, irrespective of hardware etc.
Is this a possibility, it would have huge potential, even beyond dvr type uses.
Perhaps one issue is that it wouldn\'t be instantaneous ?
Perhaps snmp functionality instead ?
