07-12-2015, 02:10 PM
I wondered if anyone can help with programming a loop in Comfort that is safe and will not overload the Bus.
Here is the application, I have CBus with a DMX gateway controlling RGB LEDs. If I wanted to create a looped response that created a rainbow or flashing what would be a safe way to do this in Comforts programming?
Can you do a \'loop until\' or call the response from the same response with maybe a flag to check each time if the loop should continue?
Any advice on a safe method?
Dayle
Dayle
