Using Sunset time to switch lights 30 minutes BEFORE sunset
By sunset, its already too dark, so I wish to switch on my garden (and some inside the house lights) N minutes before sunset time. Any suggestions?
Is it possible to read sunset time? (I have already set city, DST, etc).
There is an action under the Schedule category called Sunrise/Sunset offset where you can specify an offset to add or subtract from the sunrise or sunset time to trigger the Sunrise or sunset response
See details at http://www.comfortforums.com/forum92/1004.html
Thanks Chiu.Big Grin
CY, I\'ve tried to use an off-set as suggested, but instead of triggering a Response early, it is still triggered at Sunset.
This is the Test I used :
Offset Sunset -5Do LightON-MealsDo CLOSE GarageDoor After 300 Seconds using Timer 02
(150,1,251,74,26,194,2,1,44,49,255)
The Light turns ON AT Sunset and the Garage Door closes 5 minutes later.
I tried with a positive off-set (150,1,251,74,26,194,2,1,44,49,255), but with the same result.  Light ON at Sunset and Garage Door closed 5 minutes later.
What have I got wrong?
David
Sorry, second Response should have read (150,1,5,74,26,194,2,1,44,49,255).
David
You cannot Offset the sunset or sunrise at the Sunrise or Sunset Response itself, because when the Response happens, the Sunrise or Sunset time has already happened
The sunrise and sunset offset  should be done by Time programs say at midnight each day
see an example at http://www.comfortforums.com/view_topic.php?id=4321&forum_id=83&jump_to=19710#p19710
OK, thanks, CY.
