Threads: 31
Has anybody come across the situation where the Android app no longer turns off any alarm state,
the app carries out all other functions turns alarms on ie night/day/ alarm modes, monitoring, control etc but just will not change the state of the alarm to off. this is not the case of incorrect password.
all other functions of the app work, regardless if it is set yo LAN/Internet.......
Tried downgrading the firmware but this has had no effect, I am wondering if their is something in Comfigurator that has blocked this.
Threads: 63
Yep, I noticed this also, with the older app. I have the new v2 app installed also and if I use that one it\'s fine.[size=
][/size]It only happens when comfort is in the alarm state though. [size=
][/size]I\'ve also noticed the v2 app crashes on me every now and again. I\'m using Android.
Threads: 868
It should not have anything to do with Comfigurator unless you are logged in to Comfigurator at the same time
Can you use the 2nd generation android instead?
Threads: 31
The second generation App does turn the system of, however I opted not to use that one as the menu\'s do not allow for incremental usage ie turning volume up/down without going back to previous menu\'s which is awkward......
Maybe on the next App change this function should be be brought back into play. Im going to go back on the firmware upgrade and see if this has any effect. (Does anyone have the first generation tablet android App, lost mine)
Threads: 868
Thanks for the suggestions
We are planning to update the android apps with some new features and improvements
Threads: 31
Cool! I shall look forward to it....
Threads: 31
02-12-2015, 03:59 PM
(This post was last modified: 02-12-2015, 04:02 PM by Swiss-Toni.)
Been trying for the last week to use the 2nd generation App(tablet) on a sony Xperia tablet. original App works fine but as I said previously it cannot turn alarm state to Off.
The problem is that it will not import the jcrlccip, neither will it wiork when file is downloaded it opens file but does not load, and also I note on my phone when I use 2nd gen app you constantly have to update the camera function to view..........
